Thread: Components and Amp - Recommendations needed |
New member Username: Ochoco
Post Number: 9 Registered: Feb-08
| Posted on Tuesday, February 26, 2008 - 03:00 am: |
'08 Silverado Crew Cab. Stock Bose System. Suggestions on component replacements and an amp replacement to run them. I believe that is two front door speakers and two tweeters, and two rear door speakers and two tweeters. Not sure on the exact sizes. Not trying to win any contests, just want clean, decently loud sound. I have an AQ1200D amp and a pair of Arsenal 10" subs on the way for the lows. Was just going to upgrade there and stop but changed my mind. I will keep the stock Nav head unit still though. Also, is a crossover needed or are the ones that generally come with the components good enough? Thanks for any input. |
Relevant Product Info
Gold Member Username: Nd4spd18
Northwest PA
Post Number: 6453 Registered: Jul-06
| Posted on Tuesday, February 26, 2008 - 03:07 am: |
Are you dissatisfied with the stock system? You can certainly put a much better system in there, but it will cost some big $........ from my expierence the Bose systems are actually pretty decent. Nothing special, but pretty good as far as stock systems go. |
Post Number: 10 Registered: Feb-08
| Posted on Tuesday, February 26, 2008 - 07:32 am: |
I guess I should wait until I get my subs and amp in and go from there but from the feedback I've seen so far on the '08 Silverado Bose systems, it's not so great. My wifes old '04 Suburban bose system was noticeably louder than and sounded better than my Silverados '08. Sadly I suppose it could also be the head unit to blame, but I hope not. |
Silver Member Username: Exige
Post Number: 152 Registered: Nov-07
| Posted on Tuesday, February 26, 2008 - 11:15 am: |
I've got an 03 Suburban so if it's anything like that with the Bose system....there's definite room for improvement. With the Bose systems...it's hit and miss. The one in an A6 is pretty darn good. An amp and some new speakers would probably take care of any other concerns. Those Arsenal's will definitely help though. You can get by with a front set of components, and it'd probably sound drastically better. Let us know what you decide to do. |
Northwest PA
Post Number: 6459 Registered: Jul-06
| Posted on Tuesday, February 26, 2008 - 11:49 am: |
Yeah, if you do decide to upgrade, a 2ch amp and a good set of components for the front would prob. make all the difference. |
Bronze Member Username: Ochoco
Post Number: 11 Registered: Feb-08
| Posted on Tuesday, February 26, 2008 - 12:08 pm: |
Do you think upgrading the Head Unit would make a bigger difference than upgrading the bose amp and at least the front two speakers would. Been reading so many different views on these systems and I've read a few that have switched out head units and are happy. The two that seem to get the most praise for a replacement for the stock Nav seem to be the Pioneer D3 and the Alpine IVA-W205. I was against replacing the stock Nav head unit but after seeing some pictures of a few of these aftermarket models, they are just as clean. And most of the stock bells and whistles seem to still work, minus maybe the rear seat controls. Thanks again for the input guys, I really appreciate it. |
Northwest PA
Post Number: 6466 Registered: Jul-06
| Posted on Tuesday, February 26, 2008 - 12:19 pm: |
If you upgrade everything else, you should get a new HU. If not, don't bother, a new HU will not improve the sound much if everything else is stock. |
