Thread: Amplifier Recommendation |
Bronze Member Username: Danh
Post Number: 42 Registered: Jan-08
| Posted on Monday, February 25, 2008 - 08:17 pm: |
I'm going to be buying some new component speakers (Either Alpine Type X Reference or some variety of CDT) and a Pioneer Premier 8" Shallow sub. What I'm not sure of is which amp should I buy. Should I get: A) Eclipse XA4000 4ch (or whatever the newest one is) B) Alpine MRP-F550 (or F600) C) Alpine PDX 4.100 Also, are there any others in this price range I should look at that have comparable stats? |
Silver Member Username: Hurricanebr1an
Western Burbs of Chicago,
IL
Usa
Post Number: 350 Registered: Sep-07
| Posted on Monday, February 25, 2008 - 08:26 pm: |
You want one amp to run the comps AND the sub? Or two amps? |
Gold Member Username: Somedonniedude
Illinois
United States
Post Number: 1051 Registered: May-07
| Posted on Monday, February 25, 2008 - 08:37 pm: |
I would look into a 5 channel amp |
Gold Member Username: Nd4spd18
Northwest PA
Post Number: 6444 Registered: Jul-06
| Posted on Monday, February 25, 2008 - 09:48 pm: |
That MRP-F550 bridged to 2ch will put out some serious power, geat for a set of CDT HDs...... (thats my setup) Then get a mono amp for the sub. |
Post Number: 44 Registered: Jan-08
| Posted on Monday, February 25, 2008 - 10:34 pm: |
One amp to run the comps and the sub. The rear speakers will be powered off the HU. I've looked into 5 channel amps and they're all to weak in that range. The sub I'm talking about is only 120 watts RMS at 4 ohms with a 500 watts MAX power, so keep that in mind. |
Northwest PA
Post Number: 6449 Registered: Jul-06
| Posted on Tuesday, February 26, 2008 - 02:56 am: |
Oh, in that case the F550 would work great for you. The PDX amp would be great also but I can't justify the price on those amps. |
