Home > Message Board > Car Audio > Amplifiers > Archive through February 29, 2008 > Good Amp.
Author Thread: Good Amp.
Username: Jakez07
Marana,
United States
So anyways, basically im going to be getting either 2 12", or 10" Alpine Type X Speakers. And I'm trying to find a good non exspensive amp for them that wont underpower. (theres already enough money going into the subs).
Anyways I'm a noob at this so any ideas? I was looking at the Lanzar Vibe Series 2000W for them but im sure its cheap.
Username: Chaunb3400
Huntsville, Alabama
U.S.
Post Number: 13933
Its gonna cost you $800-$1200 to fully power those subs...Gonna need 2000rms amp, HO Alt, 0gauge wire, maybe an extra battery...Good Luck
Username: Jakez07
Marana,
United States
Hm aww man. Thats very expensive. Maybe i should get cheaper subs? But i want ones that sound good and hit hard, to shake the car.
Username: 04redmach1
Lagrange, GA
Post Number: 1638
What is the loudest setup you have heard so far? You may not need that much to get as loud as you want.
Kevin
Username: Bonhamd
Northern, Michigan
Post Number: 433
you would probably want to get a setup that does around 1000 watts rms so you don't have to upgrade your electrical system...
talk to kevin holden^^^ to get you a nice setup
or
get two dual 4 ohm type r 12s - around $250
and an audioque 1200d - $250
build your own box
http://cgi.ebay.com/PAIR-ALPINE-12-CAR-AUDIO-SUBWOOFER-3000-WATTS-TYPE-R_W0QQite mZ350029723793QQihZ022QQcategoryZ18803QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
http://www.audioque.com/aq/AQamps.htm
Username: Bnd_rulez
Phoenix, AZ
Post Number: 1594
Or you could try an ICON and Sundown amp combo. SSA has a nice promo on the combo. $499
http://www.soundsolutionsaudio.com/shop/index.php?act=viewProd&productId=150
Great SQL sub from what I have read about the ICON.
Username: Jakez07
Marana,
United States
Hm these are all great ideas. But which ones the best?
Username: Bnd_rulez
Phoenix, AZ
Post Number: 1599
Wish I knew.
I have a Type R and it is nice and all, but could be better.
I seriously contemplated that ICON/Sundown deal.
Username: Juliob
Santo Domingo
Dominican Re...
Post Number: 5195
just add another one :P!
Home > Message Board > Car Audio > Amplifiers > Archive through February 29, 2008 > Good Amp. [ « Previous ] [ Next » ]
