Thread: What amp for 2 12 type r's |
Bronze Member Username: Dupe112309
Post Number: 42 Registered: Feb-08
| Posted on Sunday, February 24, 2008 - 03:19 pm: |
2 alpine type r.....500rms each...4 ohms dvc...lookin for a bass remote too. would i need to get something for 500rms to each, or would 300-400 be sufficient? |
Silver Member Username: 2pacalypse1971
Sandusky,
Oh
Post Number: 484 Registered: Jul-05
| Posted on Sunday, February 24, 2008 - 03:31 pm: |
i got a mbquart RAA 1000 with a bass remote, i never used the bass remote so that fairly brand new, 200 shipped it could be yours, 1000 x 1 at one ohm, be perfect for them especially for stock electrical system |
Post Number: 43 Registered: Feb-08
| Posted on Sunday, February 24, 2008 - 09:20 pm: |
the type r's come either 4 ohm or 2 ohm i haven't bought them yet...how would i need to wire them? |
Sandusky,
Oh
Post Number: 485 Registered: Jul-05
| Posted on Sunday, February 24, 2008 - 10:38 pm: |
i'd reccommed the dual 4, that way they will wire down to one ohm, and even in ur not interested in my amp or whatnot, its a lot easier findin a amp with 1000 watts at one ohm rather than two, and cheaper |
Post Number: 44 Registered: Feb-08
| Posted on Sunday, February 24, 2008 - 11:36 pm: |
would an amp that was rated somewhere between 300-400 rms for each channel be sufficient for the 2 500w rms subs? or should i really try to find a good amp that will put out that 500x2? |
Bronze Member Username: Indoeli211
Post Number: 13 Registered: Feb-08
| Posted on Monday, February 25, 2008 - 01:53 am: |
i have 2 type r 12s i have a 1000x1 only a 1 channel amp it pounds rockford fastogate is the shix.. 1000wats rms shouold do ... i also have a 500 rf amp on 7 6by9s eheheh |
Gold Member Username: Bnd_rulez
Phoenix,
AZ
Post Number: 1586 Registered: Mar-05
| Posted on Monday, February 25, 2008 - 10:38 am: |
Get the AQ1200D. 1200X1 at 1 ohm. http://www.audioque.com/aq/AQamps.htm Plus it's only $249 right now. I have a Type R, and it can easily handle over 500w. |
Gold Member Username: N2audio
Lawrence,
Ks
Post Number: 1488 Registered: Mar-04
| Posted on Monday, February 25, 2008 - 10:44 am: |
300/400 each would be plenty. 500 ea would give you slightly more output, but barely enough to notice. |
Gold Member Username: Nd4spd18
Northwest PA
Post Number: 6437 Registered: Jul-06
| Posted on Monday, February 25, 2008 - 01:20 pm: |
x2 AQ 1200d amp would be great for those subs |
New member Username: Hittin_so_hard
Villa rica,
Georgia
Usa
Post Number: 9 Registered: Feb-08
| Posted on Monday, February 25, 2008 - 09:41 pm: |
i got 2 alpine type r 12's and an audioque 1200d amp and it sounds great and was only 249.......it can easily pull more than 500rms per sub |
Post Number: 47 Registered: Feb-08
| Posted on Monday, February 25, 2008 - 09:53 pm: |
so im lookin at kicker amps right now...could go with zx1000.1 and run it at 2 ohms for 500x2rms for $287.....but would i need any more power or would 500 be good enough and say 600w not really make too big a difference? |
Northwest PA
Post Number: 6447 Registered: Jul-06
| Posted on Tuesday, February 26, 2008 - 02:51 am: |
You cannot use that amp. You need a 1 ohm stable amp for those subs, like the AQ. |
Phoenix,
AZ
Post Number: 1593 Registered: Mar-05
| Posted on Tuesday, February 26, 2008 - 09:57 am: |
The AQ is cheaper, has more power and is just as good as, if not better than the Kicker amp. |
Northwest PA
Post Number: 6457 Registered: Jul-06
| Posted on Tuesday, February 26, 2008 - 11:45 am: |
I wouldn't go that far...... I'd still say the kicker is the better amp. It won't work for his subs though. |
Phoenix,
AZ
Post Number: 1600 Registered: Mar-05
| Posted on Tuesday, February 26, 2008 - 03:28 pm: |
I stand corrected. |
Northwest PA
Post Number: 6470 Registered: Jul-06
| Posted on Tuesday, February 26, 2008 - 03:33 pm: |
Oh I didn't mean it like that..... you're entitled to your opinion but mine is that they are both good amps but the Kicker's a little better. Like I said though, for those subs he needs a 1 ohm stable amp. |
Phoenix,
AZ
Post Number: 1604 Registered: Mar-05
| Posted on Tuesday, February 26, 2008 - 03:37 pm: |
I took no offense, I am still learning. |
Post Number: 49 Registered: Feb-08
| Posted on Tuesday, February 26, 2008 - 05:17 pm: |
what's the reason i need a 1 ohm stable amp? the r's come in 2 and 4 ohm if that gives me any certain amps to look at....anybody got any suggestions? i'll look for that aq. is any special wiring needed for 1 ohm or any add-ons i'll need (like for the battery)? i had stock system before and now adding 2 amps. |
Northwest PA
Post Number: 6471 Registered: Jul-06
| Posted on Tuesday, February 26, 2008 - 07:27 pm: |
In the first post you said Dual 4 ohm, so I thought thats what your subs were. If you didn't buy them yet, you can get the Dual 2 ohm, then you could use the Kicker amp or any other 2 ohm stable amp. For a 1 ohm stable amp you would get the dual 4s. |
Post Number: 51 Registered: Feb-08
| Posted on Tuesday, February 26, 2008 - 07:41 pm: |
so which setup would you reccomend?.....kicker zx1000.1 with 2 2ohm r's or the aq 1200d with 2 4ohm r's? the aq is 250 while the kicker is 287...so not too big a difference. thanks a lot for helpin a new kid out. if i have 2 amps runnin in my car one kicker 650.4 and say the 1000.1, would i need to do anything with the electrical of the car? |
Northwest PA
Post Number: 6478 Registered: Jul-06
| Posted on Tuesday, February 26, 2008 - 08:15 pm: |
I'd go with the Kicker amp....... your stock electrical system may be alright with that but theres no way to know for sure. |
Post Number: 52 Registered: Feb-08
| Posted on Tuesday, February 26, 2008 - 08:26 pm: |
what could happen? lol anything serious? also heard the type r's sound better in a sealed enclosure. was thinking about going for a dual enclosure.....but im really lookin for soem good bump comin down the road. ported or sealed? |
Northwest PA
Post Number: 6482 Registered: Jul-06
| Posted on Tuesday, February 26, 2008 - 08:33 pm: |
Do ported, still sounds good and more output....... if you draw too much current from your electrical you will see the voltage drop below 12 volts if goes you'd just have to turn it down or get HO alternator. |
Post Number: 53 Registered: Feb-08
| Posted on Tuesday, February 26, 2008 - 09:14 pm: |
alright thanks a lot M.S. you really know your stuff. |
Post Number: 54 Registered: Feb-08
| Posted on Tuesday, February 26, 2008 - 09:41 pm: |
i think i'm going to go with 0/1 ga kicker amp kits for both amps just incase i upgrade or anything |
Post Number: 55 Registered: Feb-08
| Posted on Wednesday, February 27, 2008 - 05:48 pm: |
would a capacitor be necessary? what rating should it be be if i need one? |
Northwest PA
Post Number: 6531 Registered: Jul-06
| Posted on Wednesday, February 27, 2008 - 06:43 pm: |
No capacitor they don't help Kicker amp kits are very good |
Post Number: 56 Registered: Feb-08
| Posted on Wednesday, February 27, 2008 - 10:55 pm: |
thinkin about goin through crutchfield for a ported box....could get a dual with 1.25 cu.ft/sub or a dual with 1.75/sub...would bigger be better? got 2000 mustang cpe so i gotta measure and everything. both boxes would work as for the sub needs between .75 and 2.0 cu.ft |
Northwest PA
Post Number: 6539 Registered: Jul-06
| Posted on Wednesday, February 27, 2008 - 11:39 pm: |
Definetly no prefab boxes, they suck bad except the sealed ones, those are just ok. www.fishercustoms.com www.woodlawncabinetry.com You can get a good box there. The box makes more difference than the subs in it............ |
Gold Member Username: Juliob
Santo Domingo Dominican Re...
Post Number: 5205 Registered: Dec-05
| Posted on Thursday, February 28, 2008 - 06:52 pm: |
search the subwoofer section, there are some guys selling customized boxes |
