Home > Message Board > Car Audio > Amplifiers > Archive through February 29, 2008 > The MMATS Theory
Author Thread: The MMATS Theory
Username: Tpa954
Hollywood, Florida
U.S.A
Post Number: 227
I herd that mmats do not use as much power as other large amps , which make voltage drop which cause clipping less likely and this is also why they stay so cool. What i am trying to get at is i own a mmats 3500.1 which and i have a 170 HO alt is this going to be enough ??? Also does this thing push 3500 or 2700 ???
Username: Juliob
Santo Domingo
Dominican Re...
Post Number: 5189
you need some good batteries still
Username: Nd4spd18
Northwest PA
Post Number: 6424
I would want a bigger alternator, but you can make that work. But get a good battery if you have a stock one.
Home > Message Board > Car Audio > Amplifiers > Archive through February 29, 2008 > The MMATS Theory [ « Previous ] [ Next » ]
