Home > Message Board > Car Audio > Accessories > Help?
Author Thread: Help?
Username: Deanerjr
Hey, always talked about gettin a system. I finally am. Im going to be having my back seats unbolted and lifted in my 08' Nissan Frontier 4 Door.
Right now, i have an order for 2 Kicker 12" CVR's. And i'm not sure what i should power them with. and was wondering. What else do you think i should be looking to buy as in getting those set up and running?
the description of the subs im buying are "12" Comp VR Competition Subwoofers 1,600 Watts Max Power 800 Watts RMS Power Dual 4 Ohm Voice Coils" buying them from atrusted seller on Ebay.
Relevant Product Info
Username: Basebalz13
Moneta, Va
Usa
Post Number: 281
always look at RMS bud, but do you want two amps? are jus one amp? also if your are going to be going over 1000 watts RMS then you will need to beef up your charging system or you will jus mess everything up
Post:
Username: Need to Register?
Password: Forgot Password?
Action:
Home > Message Board > Car Audio > Accessories > Help? [ « Previous ] [ Next » ]
