Home > Message Board > Car Audio > Amplifiers > Archive through February 29, 2008 > Hifonics bxi2006 help tune
Author Thread: Hifonics bxi2006 help tune
Username: Msand951
Riverside, Ca
Usa
Post Number: 46
i need help tuning my amp to this sub. http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=16056
i have it wired to a 2 ohm load and in a ported box. It bumps pretty good but i think it should do better. and it clips when i push it hard. i dont know what the knobs mean any help please. It has a gain, 180 phase, and some other ones.
Username: •cam•
BC
Post Number: 2021
Set the gain like so:
http://www.subwoofertools.com/forum/setgain.asp
Set the crossover to 80Hz. Do this by hooking up the multimeter to the amp's outputs and playing an 80Hz tone. Then you just set the x-over to full-range and turn it down 'til it starts affecting the voltage.
For the phase, just set it wherever you want. You should notice improved midbass/blending with it in one position. Play with it 'til you find which setting you prefer.
Username: Msand951
Riverside, Ca
Usa
Post Number: 47
these are the knobs it has
Subsonic 15Hz-50HZ, Bass eq 0-18db,
low pass 35-250Hz, Phase 0-180, Level 9v-0.2v
I think the level is the gain right?
Home > Message Board > Car Audio > Amplifiers > Archive through February 29, 2008 > Hifonics bxi2006 help tune [ « Previous ] [ Next » ]
