Home > Message Board > Car Audio > Amplifiers > Archive through February 29, 2008 > What amp should i use????
Author Thread: What amp should i use????
Username: Gangstagangsta
i have three kicker cvr's and i was needin to know what amp i should use something with good quility but not to expensive and also im wantin to build a box foe them and need to find out the diminsions and air space and so on want to port it also thanks
Username: Tpa954
Hollywood, Florida
U.S.A
Post Number: 225
What size CVR, also what is your budget and have you ever built a enclosure befor ??
10' $100 no i havent but my brother has
Username: Juliob
Santo Domingo
Dominican Re...
Post Number: 5187
you need to tell us voice coil configuration bro
Post Number: 7
dual voice coil 4ohm sry bout that
Username: Juliob
Santo Domingo
Dominican Re...
Post Number: 5191
kicker ZX 1500.1 at least. You guys should use pair numbers when buying woofers.
Home > Message Board > Car Audio > Amplifiers > Archive through February 29, 2008 > What amp should i use???? [ « Previous ] [ Next » ]
