Thread: Amp any good??? |
New member Username: Cory_memphis
Post Number: 1 Registered: Feb-08
| Posted on Friday, February 22, 2008 - 12:21 pm: |
i recently bought a kenwood 1000w mono amp and i have it pushing 2 12 inch memphis subs?im just wondering if this is a good amp |
Gold Member Username: N2audio
Lawrence,
Ks
Post Number: 1487 Registered: Mar-04
| Posted on Friday, February 22, 2008 - 01:02 pm: |
I've seen a LOT of owners of the k'wood class D's reporting problems/failure. One of the more common negative reports I can recall. Hopefully yours lasts a while. |
Silver Member Username: Bonhamd
Northern,
Michigan
Post Number: 426 Registered: Nov-07
| Posted on Friday, February 22, 2008 - 04:50 pm: |
my friend tyson had a kenwood excelon amp on his 10w7 and it did okay and never had problems but he tried telling me it was better than a 500/1. |
Gold Member Username: Juliob
Santo Domingo Dominican Re...
Post Number: 5183 Registered: Dec-05
| Posted on Friday, February 22, 2008 - 05:08 pm: |
bad power supplies |
Platinum Member Username: Bestmankind
Los Angeles,
CA
Post Number: 18680 Registered: Oct-05
| Posted on Friday, February 22, 2008 - 05:15 pm: |
get a different amp. kenwoods are overrated and have a high failure rate. |
Gold Member Username: Nd4spd18
Northwest PA
Post Number: 6422 Registered: Jul-06
| Posted on Sunday, February 24, 2008 - 02:24 pm: |
Kenwood is one of the worst brands of amplifiers....... they have a very high failure rate b/c their power supplies are crap |
Post Number: 5 Registered: Feb-08
| Posted on Monday, February 25, 2008 - 12:08 pm: |
would a memphis 500 watt blow this kenwood away? |
Northwest PA
Post Number: 6438 Registered: Jul-06
| Posted on Monday, February 25, 2008 - 01:23 pm: |
In power obviously not. When the kenwood blows, just make sure to get a good quality amp next time. |
Post Number: 7 Registered: Feb-08
| Posted on Tuesday, February 26, 2008 - 11:43 am: |
what kind of amp around $200 would you recommend? |
Northwest PA
Post Number: 6458 Registered: Jul-06
| Posted on Tuesday, February 26, 2008 - 11:47 am: |
Thats a little low...... you can get a good 1000w amp for $250-300 Does it need to be 1 ohm or 2 ohm stable (what ohm coils are the subs) |
Post Number: 8 Registered: Feb-08
| Posted on Tuesday, February 26, 2008 - 11:54 am: |
4 ohm dvc |
Northwest PA
Post Number: 6465 Registered: Jul-06
| Posted on Tuesday, February 26, 2008 - 12:15 pm: |
Then look into an Audioque 1200d www.audioque.com $250 Cheapest good quality amp you'll find |
