Thread: Yes r no? |
Silver Member Username: Stateprop486
PA
Post Number: 560 Registered: Jan-08
| Posted on Thursday, February 21, 2008 - 04:21 pm: |
i wanted to get an amp for my comps that i yet have a chance to install waiting for spring to come and i was thinkin of getting the kx200.2 r the kx350.2, do you guys think i would have to upgrade my alt or will it b able to do fine on stock alt. my alt is 80amps now, and im currently runnin an zx1000.1....and i dnt have the big 3 done r nething. possible? sorry for a newb question. lol just curious |
Platinum Member Username: Bestmankind
Los Angeles,
CA
Post Number: 18567 Registered: Oct-05
| Posted on Thursday, February 21, 2008 - 04:24 pm: |
at least do the big 3. also go with the 200.2. you don't need that much power for your comps. you got the alpines right? |
PA
Post Number: 562 Registered: Jan-08
| Posted on Thursday, February 21, 2008 - 04:25 pm: |
yeah bro, lol the big 3 looks complicated. haha..i lookd at ma wires, and sum of them is hidden n stuff...i have an 99 camry..what is a good tool to use to cut thru the door panels to install the tweeters chad? |
Los Angeles,
CA
Post Number: 18569 Registered: Oct-05
| Posted on Thursday, February 21, 2008 - 04:27 pm: |
dremel? |
PA
Post Number: 565 Registered: Jan-08
| Posted on Thursday, February 21, 2008 - 04:33 pm: |
lol is that only a guess? r not sure? |
