Thread: Scott S |
Silver Member Username: Kingandsons07
Lincoln,
Nebraska
U.S.A
Post Number: 728 Registered: Feb-07
| Posted on Thursday, February 21, 2008 - 08:59 am: |
can u help me i'm tryin to get on team revolution i'm wantin to run 4 18" Alpha the V.2 thanks scott |
Silver Member Username: Talon01
Team revolution ,
Pa
Usa
Post Number: 854 Registered: Jun-07
| Posted on Thursday, February 21, 2008 - 09:06 am: |
contact steve or kenny at rdaudio.net. fill out the form and submit it through the site. whats your background on comps, are you a member of db drag, iasca, meca and so on. |
Lincoln,
Nebraska
U.S.A
Post Number: 729 Registered: Feb-07
| Posted on Thursday, February 21, 2008 - 09:11 am: |
i'm gettin started on comps i got a 2000 E250 is what i'm going to use i'm trying to get on there forums and it wont let me loge in? kevin is helpin too |
Team revolution ,
Pa
Usa
Post Number: 855 Registered: Jun-07
| Posted on Thursday, February 21, 2008 - 09:24 am: |
kevin is in direct contact with kenny, he will be able to help you more than me. do i hear a wall coming soon in the e250. as for the forum , yor already reg. right |
Lincoln,
Nebraska
U.S.A
Post Number: 731 Registered: Feb-07
| Posted on Thursday, February 21, 2008 - 09:29 am: |
yep it says i'm in there if u look but i can't loge? yep a wall bed liner all of the van ftw kevin was tellin me about some kinda new batt coming out better then th hc2400? |
Gold Member Username: Insearchofbass
Post Number: 8085 Registered: Jun-04
| Posted on Thursday, February 21, 2008 - 09:30 am: |
eventually i wouldnt mind getting on the rd team but I dont wanna mess up my iasca rookie 1 requirements |
Team revolution ,
Pa
Usa
Post Number: 856 Registered: Jun-07
| Posted on Thursday, February 21, 2008 - 09:35 am: |
i know he has been having problems with the phone and network. that might be the issue? not sure tho. also yeah there is a new battery coming soon its a beast. sean, team rd wont mess up your rookie class, let me know if dhl shows up today, put a post up if they do |
Lincoln,
Nebraska
U.S.A
Post Number: 733 Registered: Feb-07
| Posted on Thursday, February 21, 2008 - 09:36 am: |
well i want to get in to comp now i hate the shop here so i want to get something thats going to blow them away they are tellin me i don't know what i'm doing lol |
Post Number: 8086 Registered: Jun-04
| Posted on Thursday, February 21, 2008 - 09:41 am: |
yeah i think it will ....I think you cant have any connections to a company |
Team revolution ,
Pa
Usa
Post Number: 857 Registered: Jun-07
| Posted on Thursday, February 21, 2008 - 09:48 am: |
i'll help as much as i can quentin, sean as long as you can provide at reciept you are fine, per terry |
Post Number: 8087 Registered: Jun-04
| Posted on Thursday, February 21, 2008 - 09:50 am: |
"they are tellin me i don't know what i'm doing lol" well everyone has to start somewhere and no one knows it all...and if you dont do well at first youll improve over time...but get a termlab for sure |
Post Number: 8088 Registered: Jun-04
| Posted on Thursday, February 21, 2008 - 09:55 am: |
well as long as its by the book Scott ill do it...ill go over to your place to check on the delivery... it should get there before I go away |
Lincoln,
Nebraska
U.S.A
Post Number: 735 Registered: Feb-07
| Posted on Thursday, February 21, 2008 - 09:56 am: |
were can i get a termlab? dosen't that tell u ur db if i recall? yea they are as$ here like buy our stuff everthing eles sucks and have us put it in. lol. thanks scott!! |
Team revolution ,
Pa
Usa
Post Number: 858 Registered: Jun-07
| Posted on Thursday, February 21, 2008 - 10:00 am: |
termlabs are 800.00 new and yes they read db , also freq. yw |
Post Number: 8089 Registered: Jun-04
| Posted on Thursday, February 21, 2008 - 10:01 am: |
see if zac davis has anymore or buy it brand new http://www.termpro.com/term-lab/index.asp |
Lincoln,
Nebraska
U.S.A
Post Number: 736 Registered: Feb-07
| Posted on Thursday, February 21, 2008 - 10:02 am: |
yea i'll get one too |
