Home > Message Board > Car Audio > Amplifiers > Archive through February 29, 2008 > HELP PLEASE!!!! NEW AMP!!!
Author Thread: HELP PLEASE!!!! NEW AMP!!!
Username: Johnc874
Hi all,
I just got a new amp for my 2 kicker 8in cvr's. I used to have a rockford fosgate punch amp that worked well for about a year until for some reason my fuses were getting extremely hot and melted the system (im not sure if it was bypassing the fuses or what but the fuses would never blow just melt). Anyways, I was sold into a monoblock infinity amp that pushes 1300watts. When I hooked the amp up and connected the RMS cables the subs immidiatly started to play at a constant low tone. When I unplugged the RMS cables they stopped. I checked all of my wires and the internals in the box's but nothing looks out of place. Someone please help I am completely stumped.
Username: Evoixmr
Post Number: 162
RMS cables?
Username: Southernrebel
Monroe, Louisiana
2 DD3515s, 2...
Post Number: 5978
check your ground and make sure your RCA's are not messed up.
Username: Johnc874
Im sorry I meant RCA's but my ground is fine the amp is turning on but I even tried switching the RCA's but it does the same thing either way. Its just a constant low toned noise coming from both subs
Username: Evoixmr
Post Number: 164
Take the cover off the amp and check for any visable damage to circutry.
Username: Its_bacon12
Hfl, Ny
Usa
Post Number: 1260
i would check the source of your RCAs..
it sounds like you;re getting some nasty interference or your source is very poor.. or there is some kind of loose connection
Home > Message Board > Car Audio > Amplifiers > Archive through February 29, 2008 > HELP PLEASE!!!! NEW AMP!!! [ « Previous ] [ Next » ]
