Thread: About the audioque 1200d |
Bronze Member Username: Alpine_player
Villa rica,
Georgia
United States
Post Number: 30 Registered: Feb-08
| Posted on Wednesday, February 20, 2008 - 11:22 pm: |
will this amp make my headlights dim?>......am i gonna need another battery?......am i gonna need a voltage meter?>........is it that much power.....is my battery gonna run donw that fast.....because if so i dont kno...... |
Gold Member Username: •cam•
BC
Post Number: 1986 Registered: Nov-06
| Posted on Wednesday, February 20, 2008 - 11:25 pm: |
You'll probably be fine. I was drawing probably upwards of 150A on peaks from a stock 55A alternator, single stock battery, and no big 3 with no problems. I just had to watch it on tones, then give my battery lots of time to charge up. It will depend on the draw of other stuff, such as air conditioning. A voltage meter is a good idea. |
Villa rica,
Georgia
United States
Post Number: 32 Registered: Feb-08
| Posted on Wednesday, February 20, 2008 - 11:27 pm: |
wat exactly does a volatge meter do?>.......i was jus wonderin because i jus want some hard hittin bass but i dont want to end up spendin a crap load of other money jus to keep my car runnin |
Silver Member Username: Snowball123
West Allis,
WI
United States
Post Number: 367 Registered: Oct-07
| Posted on Wednesday, February 20, 2008 - 11:29 pm: |
voltage meter just tells you how many volts are running to your amp. |
West Allis,
WI
United States
Post Number: 368 Registered: Oct-07
| Posted on Wednesday, February 20, 2008 - 11:30 pm: |
you should try to find out what size alternator you have right now. |
Villa rica,
Georgia
United States
Post Number: 33 Registered: Feb-08
| Posted on Wednesday, February 20, 2008 - 11:31 pm: |
wat happens if it gets to hi or to low? |
Gold Member Username: Nd4spd18
Northwest PA
Post Number: 6380 Registered: Jul-06
| Posted on Wednesday, February 20, 2008 - 11:34 pm: |
That amp will most likely be fine, don't worry about it. Yes your lights will probably dim. That happens even with beefed up electrical systems a lot of times. |
Villa rica,
Georgia
United States
Post Number: 36 Registered: Feb-08
| Posted on Wednesday, February 20, 2008 - 11:38 pm: |
aight..........i wanna be sure...........how ofter will i probably be changin my battery........i went from wantin a 1000 watt kenwood amp to this amp cause every body said that amp sucked and i only want the best |
Gold Member Username: Spivey17323
Dunellen,
New jersey
15 inch Alph...
Post Number: 1235 Registered: Jun-07
| Posted on Wednesday, February 20, 2008 - 11:40 pm: |
iran 1200 watts an a stock electrical and i was fine and had no dimming at all. a tiny bit when i had the colume cranked. you'll be fine bro trust us |
Northwest PA
Post Number: 6385 Registered: Jul-06
say what??????? You don't change your battery..... |
West Allis,
WI
United States
Post Number: 370 Registered: Oct-07
| Posted on Wednesday, February 20, 2008 - 11:41 pm: |
alternator is what is most important. not a battery. |
Villa rica,
Georgia
United States
Post Number: 39 Registered: Feb-08
| Posted on Wednesday, February 20, 2008 - 11:42 pm: |
i know i meant alternator........but itll be fine..........nevermind |
West Allis,
WI
United States
Post Number: 372 Registered: Oct-07
| Posted on Wednesday, February 20, 2008 - 11:47 pm: |
so you meant youd be changin your alternator all the time? |
Villa rica,
Georgia
United States
Post Number: 40 Registered: Feb-08
| Posted on Wednesday, February 20, 2008 - 11:49 pm: |
i was wonderin if i woul have to |
Northwest PA
Post Number: 6388 Registered: Jul-06
| Posted on Wednesday, February 20, 2008 - 11:53 pm: |
Haha no |
Villa rica,
Georgia
United States
Post Number: 42 Registered: Feb-08
| Posted on Wednesday, February 20, 2008 - 11:54 pm: |
i dont kno if i wan to install all this stuff my self or not and jus pay somebody to do it...... |
Gold Member Username: Somedonniedude
Illinois
United States
Post Number: 1017 Registered: May-07
| Posted on Wednesday, February 20, 2008 - 11:57 pm: |
"wat happens if it gets to hi or to low?" Dont worry about it getting to high, just watch for when it starts dropping to 12ish volts. If it gets too low, you will kill your battery and possibly fry your amp. 12.5 volts and up is stable, anything below you are loosing ground. You will mainly have to watch it at idle if you have it cranked with alot of things running like light, wipers, etc. |
Villa rica,
Georgia
United States
Post Number: 43 Registered: Feb-08
| Posted on Thursday, February 21, 2008 - 06:02 pm: |
i didnt kno if it would blow the subs or not becaue the amps 1200 rms and the subs are 500 rms appeace and thats kinda like 600 rms to each sub so...... |
Silver Member Username: Nickyp0219
Post Number: 692 Registered: Jun-06
| Posted on Thursday, February 21, 2008 - 06:22 pm: |
nah thats chump change for the type r's...youll be fine |
