Thread: AMP FOR 2 ALPINE 12" TYPE R'S |
New member Username: Alpine_player
Villa rica,
Georgia
United States
Post Number: 3 Registered: Feb-08
| Posted on Wednesday, February 20, 2008 - 09:45 pm: |
wat kind of amp is recommended for 2 alpine 12" type R's ........4 ohm.....500rms each......?........i was looking at a kenwood 1000watt amp but i dont kno? |
Silver Member Username: Spankinurwoofers
GR,
MI
US
Post Number: 276 Registered: Nov-07
| Posted on Wednesday, February 20, 2008 - 09:47 pm: |
From what i've heard kenwood amps pretty much suck. What's your budget? |
Bronze Member Username: Alex_smith
Post Number: 76 Registered: Sep-07
| Posted on Wednesday, February 20, 2008 - 09:50 pm: |
stay away from kenwood far away |
Gold Member Username: Spivey17323
Dunellen,
New jersey
15 inch Alph...
Post Number: 1223 Registered: Jun-07
| Posted on Wednesday, February 20, 2008 - 09:54 pm: |
massive p1000- i had this one when i used to have type r's. perfect match sundown 1000d audioque 1200d rf 1000bd those are just a few. u said they were dv4's right? |
Villa rica,
Georgia
United States
Post Number: 4 Registered: Feb-08
| Posted on Wednesday, February 20, 2008 - 09:57 pm: |
my budget is under around 350 or so....... |
Silver Member Username: Hurricanebr1an
Western Burbs of Chicago,
IL
Usa
Post Number: 343 Registered: Sep-07
| Posted on Wednesday, February 20, 2008 - 09:59 pm: |
audioque 1200d is perfect then |
Villa rica,
Georgia
United States
Post Number: 5 Registered: Feb-08
| Posted on Wednesday, February 20, 2008 - 10:02 pm: |
aight.......is it best to get 2 amps, one for each sub, or jus one to power both of them? |
Dunellen,
New jersey
15 inch Alph...
Post Number: 1225 Registered: Jun-07
| Posted on Wednesday, February 20, 2008 - 10:04 pm: |
http://www.audioque.com/aq/AQamps.htm get it. best deal and perfect for your budget. ull save money and still have a great amp |
Villa rica,
Georgia
United States
Post Number: 6 Registered: Feb-08
| Posted on Wednesday, February 20, 2008 - 10:05 pm: |
cool man thanks.......thats been buggin me forever now.......wat about an enclosure? |
Gold Member Username: Ctmike
Ct.
Post Number: 5870 Registered: Feb-06
| Posted on Wednesday, February 20, 2008 - 10:07 pm: |
ported. about 3.5cuft after displacements tuned to about 32-35hz. could go a bit bigger if you want/can. |
Gold Member Username: Jnoel
AIM= j69noel,
KY
Post Number: 1035 Registered: May-07
| Posted on Wednesday, February 20, 2008 - 10:09 pm: |
i would suggest a mean machines 2000.1 it would fit them nicely...... they say 500 rms but thay take 1000 wit ease |
Villa rica,
Georgia
United States
Post Number: 10 Registered: Feb-08
| Posted on Wednesday, February 20, 2008 - 10:17 pm: |
does anybody have the audioque 1200D amp? is so how do you got it tuned?...... |
Silver Member Username: Snowball123
West Allis,
WI
United States
Post Number: 352 Registered: Oct-07
| Posted on Wednesday, February 20, 2008 - 10:21 pm: |
you dont tune the amp. |
GR,
MI
US
Post Number: 279 Registered: Nov-07
| Posted on Wednesday, February 20, 2008 - 10:22 pm: |
i was gonna go with two audiobahn a8000t's(800 rms actual output, got a good deal on em too... )...but then i decided on different subs i was told this would be about as much as you should put to type r's(800 rms a piece) |
Bronze Member Username: Alpine_player
Villa rica,
Georgia
United States
Post Number: 12 Registered: Feb-08
| Posted on Wednesday, February 20, 2008 - 10:24 pm: |
yea thats a shitload of rms per sub but hell yea......... |
AIM= j69noel,
KY
Post Number: 1036 Registered: May-07
| Posted on Wednesday, February 20, 2008 - 10:25 pm: |
^ you were told wrong wytee |
West Allis,
WI
United States
Post Number: 353 Registered: Oct-07
| Posted on Wednesday, February 20, 2008 - 10:27 pm: |
yeah people have put like 1000 on one type r ive heard. |
GR,
MI
US
Post Number: 280 Registered: Nov-07
| Posted on Wednesday, February 20, 2008 - 10:28 pm: |
well, i think it was more like a "most ppl don't put more than this to em" than a "that's the max rms to put on em"...but either way, going with a different setup anyways. ^ @ j noel |
Dunellen,
New jersey
15 inch Alph...
Post Number: 1229 Registered: Jun-07
| Posted on Wednesday, February 20, 2008 - 10:29 pm: |
use the money you saved and have woodlawn cabintery make you a custom box to the specs of the sub. the box makes all the difference man. you could have the best subs but if your box sucks your subs dont mean sh*t. dont buy a box off ebay haha |
West Allis,
WI
United States
Post Number: 354 Registered: Oct-07
| Posted on Wednesday, February 20, 2008 - 10:30 pm: |
what you gettin then. |
Dunellen,
New jersey
15 inch Alph...
Post Number: 1230 Registered: Jun-07
| Posted on Wednesday, February 20, 2008 - 10:33 pm: |
dont put that much on the r. they get pleanty loud for you with 500 each. trust me i had em. if this is your first system you dont wanna put that much over the rms on your subs because chances are you'll mess em up. if i were you i would put like 600-700 rms each to em. |
West Allis,
WI
United States
Post Number: 357 Registered: Oct-07
| Posted on Wednesday, February 20, 2008 - 10:38 pm: |
yeah usually the people puttin 1000 on a type r know what they are doing. |
GR,
MI
US
Post Number: 283 Registered: Nov-07
| Posted on Wednesday, February 20, 2008 - 10:42 pm: |
^^^"what you gettin then" @ me snow? i'm gettin two 12" re se's |
West Allis,
WI
United States
Post Number: 360 Registered: Oct-07
| Posted on Wednesday, February 20, 2008 - 10:45 pm: |
yeah. those are nice subs. but whyd you get two of those audiobahn amps. instead of just getting one amp and a better brand. |
GR,
MI
US
Post Number: 285 Registered: Nov-07
| Posted on Wednesday, February 20, 2008 - 10:47 pm: |
i got the 2 a8000t's for $170 from dwight...couldn't pass it up i guess. i know they're not the BEST amps, but they'll work, it's only my second system so i'll upgrade eventually |
Gold Member Username: Somedonniedude
Illinois
United States
Post Number: 1008 Registered: May-07
| Posted on Wednesday, February 20, 2008 - 10:50 pm: |
If your vehicle doesnt have a volt meter, I would seriously get one. Thats alot of power on a stock electrical (assuming you have no electrical upgrades). What kind of vehicle is this going into? |
GR,
MI
US
Post Number: 287 Registered: Nov-07
| Posted on Wednesday, February 20, 2008 - 10:53 pm: |
not sure if you're talkin to me now or to gunner...seeing as this is/was his thread, lol. sorry if i just jacked ur thread gunner well if you ARE talking to me...'98 jetta, vr6. no volt meter yet, already looking at getting one, and stock electrical so far(well, interstate batt, came with car) |
Villa rica,
Georgia
United States
Post Number: 20 Registered: Feb-08
| Posted on Wednesday, February 20, 2008 - 10:57 pm: |
naw its straight ......he is prob talkin to you anyway........u lookin to pull more power than me anyways..............but it dont matter.......i got wat i needed |
Illinois
United States
Post Number: 1009 Registered: May-07
| Posted on Wednesday, February 20, 2008 - 10:59 pm: |
lol I was talking to gunner. |
GR,
MI
US
Post Number: 288 Registered: Nov-07
| Posted on Wednesday, February 20, 2008 - 11:00 pm: |
lol, oops...my bad then  |
Villa rica,
Georgia
United States
Post Number: 26 Registered: Feb-08
| Posted on Wednesday, February 20, 2008 - 11:04 pm: |
this is gunner........i change my name thing.......... |
Illinois
United States
Post Number: 1011 Registered: May-07
| Posted on Wednesday, February 20, 2008 - 11:15 pm: |
Repen, I would recommend getting a volt meter if you car doesnt have on already. 1200+ watts is a good strain on stock electrical. If you pull too much power and dont know it, you could easily fry an amp. Also, consider what josh said about a box. A sub is only as good as the box it goes into. A good custom box can be 3x as loud as a bad box. |
Villa rica,
Georgia
United States
Post Number: 29 Registered: Feb-08
| Posted on Wednesday, February 20, 2008 - 11:17 pm: |
yea i alrady kno that a bout the box but wat exactly is a volt meter?....... |
Illinois
United States
Post Number: 1014 Registered: May-07
| Posted on Wednesday, February 20, 2008 - 11:26 pm: |
IL
Usa
Post Number: 344 Registered: Sep-07
| Posted on Thursday, February 21, 2008 - 08:57 am: |
what vehicle do you have repen/gunner? And getting a custom enclosure will cost you, but be worth it. And a Type R that gets 500wmrs vs. 700wmrs wont be that noticable. But it will increase your chance of it being blown. I recommend FisherCustoms for the box...$160 for 3.5 cubes (thats what ctmike recommended). http://fishercustoms.com/ |
Gold Member Username: Insearchofbass
Post Number: 8084 Registered: Jun-04
| Posted on Thursday, February 21, 2008 - 09:05 am: |
or if you want to learn how to build a box you can and save some cash again...we will help you if you have any questions |
Gold Member Username: Mygame5982
I Got More Watts Then ...,
TEXAS
US
Post Number: 2471 Registered: Jan-06
| Posted on Thursday, February 21, 2008 - 03:07 pm: |
i just sold my type rs but i had a orion 2500 on them!!! and you can get one for bout three fifty.. |
Silver Member Username: Shade
Moxee,
Wa
U.S.
Post Number: 582 Registered: Nov-06
| Posted on Thursday, February 21, 2008 - 03:18 pm: |
i have a TCAB box that was made for 2-Type R 12's. it's a common chamber with a flared port, tuned around 34hz. lmk |
