Thread: Will 4 gauge wire work? |
Bronze Member Username: Diehlerman
Post Number: 11 Registered: Jan-08
| Posted on Wednesday, February 20, 2008 - 01:35 pm: |
here in the next couple of weeks I'm going to be installing 2 10" compVR's in my girlfriends jeep, just wondering if 4 gauge power wire will be adequate for 600w RMS? |
Relevant Product Info
Gold Member Username: Nd4spd18
Northwest PA
Post Number: 6364 Registered: Jul-06
| Posted on Wednesday, February 20, 2008 - 02:03 pm: |
Yes, I don't know of any 600w rms amp that would need bigger wire than that |
Gold Member Username: Th3pwn3r
Post Number:...
Post Number: 6966 Registered: Jul-06
| Posted on Wednesday, February 20, 2008 - 03:12 pm: |
Me either but an extremely inefficient amp would need more current of course but 600 watts RMS isn't much so you should be fine on with 4 gauge. |
Silver Member Username: Waresgaragestereo
Fort Valley,
GA
United States
Post Number: 147 Registered: Jan-08
| Posted on Wednesday, February 20, 2008 - 10:33 pm: |
my system works very well with that wire. for your speakers tho, they say to use 12 ga wire. thats what i did. 12ga speaker wire is in my car and every other car i've seen or worked on. this is only for subs. |
