Home > Message Board > Car Audio > Amplifiers > Archive through February 29, 2008 > Will tihs amp work?
Author Thread: Will tihs amp work?
Username: Justin_13
Post Number: 18
will a sound storm FY1802 amp work with two kicker cvr 12" 4 ohm subs?
Username: N2audio
Lawrence, Ks
Post Number: 1481
to get the best out of those subs? not even close.
to give you some noise until you can save up for something better quality, yes.
It will work best if the subs are dvc 4's.
Username: Justin_13
Post Number: 22
they are dvc 4s but how would i wire them?
Username: Tweidner674
Post Number: 12
you'd be better off getting a mono amp that does 800-1000 watts at 1 ohm. i have those same subs and i'm looking for an amp right now that'll do just that.
Username: Th3pwn3r
Post Number:...
Post Number: 6956
Wire all in parallel or all positives and negatives together so that you get a 1Ohm load and you'll be good to go.
Username: N2audio
Lawrence, Ks
Post Number: 1484
for the soundstorm you'd want a 4 ohm load, not 1. It's done like this...
Username: Th3pwn3r
Post Number:...
Post Number: 6969
For the soundstorm you'd want to throw it in the trash. That's complete garbage.
Username: Juliob
Santo Domingo
Dominican Re...
Post Number: 5185
why don't you try hifonics instead?
Home > Message Board > Car Audio > Amplifiers > Archive through February 29, 2008 > Will tihs amp work? [ « Previous ] [ Next » ]
