Thread: 2 kicker L5s 15", best amp for the job? |
Bronze Member Username: Leapoldstotch
Post Number: 50 Registered: Nov-07
| Posted on Wednesday, February 20, 2008 - 10:27 am: |
my friends getting 2 kicker L5s 15"s and i was thinkin run the 1000.1 kicker>? anyone else have any ideas for a better amp? |
Gold Member Username: Insearchofbass
Post Number: 8052 Registered: Jun-04
| Posted on Wednesday, February 20, 2008 - 10:30 am: |
talk him out of the l5's they dont sound very good...theres better for the money |
Post Number: 51 Registered: Nov-07
| Posted on Wednesday, February 20, 2008 - 10:35 am: |
hes getting them for only 200 bucks, what would u reccomened thats better for the money? |
Post Number: 8053 Registered: Jun-04
| Posted on Wednesday, February 20, 2008 - 10:45 am: |
well its hard to beat that price but im sure they are used |
Post Number: 8054 Registered: Jun-04
| Posted on Wednesday, February 20, 2008 - 10:47 am: |
dual 4 ohm voice coils? |
Post Number: 53 Registered: Nov-07
| Posted on Wednesday, February 20, 2008 - 10:49 am: |
hes not sure, but if your giong to wire them with a 2 channel amp dont uhave to have 2 ohm? |
Silver Member Username: Stateprop486
PA
Post Number: 521 Registered: Jan-08
| Posted on Wednesday, February 20, 2008 - 11:01 am: |
DUDE STOP MAKIN THREADS ABOUT THE SAME STUFF R EVERY IDEA THAT COMES TO UR HEAD!!! http://forum.ecoustics.com/bbs/messages/4/451121.html http://forum.ecoustics.com/bbs/messages/4/451152.html http://forum.ecoustics.com/bbs/messages/4/451245.html http://forum.ecoustics.com/bbs/messages/4/451240.html http://forum.ecoustics.com/bbs/messages/4/451345.html http://forum.ecoustics.com/bbs/messages/4/451344.html u made 6 threads...wow... |
Post Number: 8055 Registered: Jun-04
| Posted on Wednesday, February 20, 2008 - 11:05 am: |
OneChannelOperation These ZX amplifiers are capable of operating into a minimum impedance of 2 ohms. If you are using multiple voice coils, the net impedance of the voice coils must be equal to or greater than 2 ohms. you cant use two l5 15's that are dual 4 ohm you will need dual 2 ohms to get the right ohm load with the kicker amp and its a mono block (one channel) you dont want to run subs in stereo anyway |
Post Number: 54 Registered: Nov-07
| Posted on Wednesday, February 20, 2008 - 05:18 pm: |
so to use a monoblock amp u gotta have 2 ohms right? for any subs and any amp? |
Post Number: 8078 Registered: Jun-04
| Posted on Wednesday, February 20, 2008 - 05:21 pm: |
different mono blocks have different ohm loads they are stable to...youll have to look...but you also have to know the voice coil ohms on your subwoofers to know what ohm load you need |
Post Number: 58 Registered: Nov-07
| Posted on Wednesday, February 20, 2008 - 05:28 pm: |
ohhh duh.. so if i get idk.. say type Rs, u can get 2 ohm or 4 ohm subs. i knwo that. and u have to match that with how many ohms ur running your amp at? so pretty much always 2 ohm subs? how would a 1 ohom stable work out? |
Gold Member Username: Spivey17323
Dunellen,
New jersey
15 inch Alph...
Post Number: 1220 Registered: Jun-07
| Posted on Wednesday, February 20, 2008 - 05:34 pm: |
if u get 2 d4's u need an amp stable at 1 ohm if you have 2 d2 subs you need an amp stable at 2 ohms. does that answer your question? |
