Thread: 93 ford ranger |
Anonymous |
| Posted on Thursday, August 14, 2003 - 12:42 pm: |
i have a 93 ford ranger and i just blew out the speakers. i wnat to get some speakers soon but i dont know what size would fit the doors. so im here asking and pleeding for help! can you help me!? |
Anonymous |
| Posted on Tuesday, September 02, 2003 - 02:58 pm: |
My advice to you would be to get all after market quality speakers. Don't worry about replacing the door speakers with the same as a factory system, instead get tweeters and some small subs that would fit under or behind the seat. This will be slightly mopre expensive, but the sound quality will be worth the effort. |
DirtTrackRacer |
| Posted on Tuesday, September 02, 2003 - 05:06 pm: |
http://www.crutchfield.com/cgi-bin/S-9ce0QjPievC/ProdGroup.asp?s=0&cc=01&a=1&g=52200&l=C&fit=E&size=6X8 http://www.crutchfield.com/cgi-bin/S-9ce0QjPievC/ProdGroup.asp?s=0&cc=01&a=1&g=76300&l=C&fit=P&size=5+1%2F4 http://www.crutchfield.com/cgi-bin/S-9ce0QjPievC/ProdGroup.asp?s=0&cc=01&a=1&g=52200&l=J&fit=E&size=6X8 http://www.crutchfield.com/cgi-bin/S-9ce0QjPievC/ProdGroup.asp?s=0&cc=01&a=1&g=76300&l=J&fit=P&size=5+1%2F4 I would go with Alpine, Rockford Fosgate, Infinity Kappa or MB Quart on a amp. |
