Thread: Problem?!?!? |
Bronze Member Username: Davidt487
Texas
Post Number: 93 Registered: Dec-07
| Posted on Tuesday, February 19, 2008 - 12:51 pm: |
Im still trying to figure out what could be causing me to have to turn the gain on my amp 3/4 of the way up to get any power from it. i cant figure out what could be causing this |
Silver Member Username: Bonhamd
Northern,
Michigan
Post Number: 336 Registered: Nov-07
| Posted on Tuesday, February 19, 2008 - 12:55 pm: |
maybe bad connections or bad pre out voltage get a dmm on the amp and check |
Silver Member Username: Surferdude9371
Im BTL Bumpin
Post Number: 682 Registered: Mar-07
all the connections good? |
Im BTL Bumpin
Post Number: 683 Registered: Mar-07
make sure the rcas r fully plugged in the back of the hu |
Texas
Post Number: 94 Registered: Dec-07
| Posted on Tuesday, February 19, 2008 - 01:52 pm: |
ive been over everything several times it works but i have to turn the gain up to 3/4 to get any real power from my amp hifonics 2006d eclipse cd8445 (8 volts) |
Im BTL Bumpin
Post Number: 684 Registered: Mar-07
| Posted on Tuesday, February 19, 2008 - 01:56 pm: |
sounds like a bad amp |
Silver Member Username: Shade
Moxee,
Wa
U.S.
Post Number: 567 Registered: Nov-06
| Posted on Tuesday, February 19, 2008 - 02:08 pm: |
sub volume on the deck is at?! |
Texas
Post Number: 95 Registered: Dec-07
| Posted on Tuesday, February 19, 2008 - 02:57 pm: |
6 |
Moxee,
Wa
U.S.
Post Number: 568 Registered: Nov-06
| Posted on Tuesday, February 19, 2008 - 03:06 pm: |
what are your subs wired too? |
Texas
Post Number: 96 Registered: Dec-07
| Posted on Tuesday, February 19, 2008 - 03:10 pm: |
1 ohm 12" re sx dual 2 |
Gold Member Username: Southernrebel
Monroe,
Louisiana
2 DD3515s, 2...
Post Number: 5967 Registered: Mar-04
| Posted on Tuesday, February 19, 2008 - 10:17 pm: |
Check the cross-over settings on the amp and Hu. Also, check the RCA's and make sure you are getting a good signal to the amp. |
Texas
Post Number: 100 Registered: Dec-07
| Posted on Wednesday, February 20, 2008 - 03:50 pm: |
ive been through the setting several times if thats it ill never find it. i called eclipse they said there is no what to check the output voltage with out an o scope and i dont have on so. |
Gold Member Username: Nd4spd18
Northwest PA
Post Number: 6370 Registered: Jul-06
| Posted on Wednesday, February 20, 2008 - 04:33 pm: |
BS you use use a DMM to check voltage Scope is needed to benchtesting output power though. |
Silver Member Username: Davidt487
Texas
Post Number: 102 Registered: Dec-07
| Posted on Wednesday, February 20, 2008 - 04:36 pm: |
that is what the guy at eclipse tech support told me. also i thought i might have a ground problem so i ran 0 guage from the frame to the - battery terminal and from the firewall to the - terminal now my voltage runs at like 15 is that good or bad? |
Monroe,
Louisiana
2 DD3515s, 2...
Post Number: 5970 Registered: Mar-04
| Posted on Wednesday, February 20, 2008 - 04:51 pm: |
Do you have another amp you can hook up just to test? Try that if you can. Also, to test output on the RCA's...Just use a DMM. Disconect the RCA's from the amp and put one lead on the center pin and another on the outer casing. Run a 60hz tone and see what voltage you get at the RCA. |
Texas
Post Number: 103 Registered: Dec-07
| Posted on Wednesday, February 20, 2008 - 05:01 pm: |
what should i set the dmm to ac or dc |
Monroe,
Louisiana
2 DD3515s, 2...
Post Number: 5971 Registered: Mar-04
| Posted on Wednesday, February 20, 2008 - 05:13 pm: |
Ac |
Texas
Post Number: 104 Registered: Dec-07
| Posted on Thursday, February 21, 2008 - 09:32 am: |
first off i have a cheap dmm but i couldnt get a a tenth out so should i just pack up my cd player and send it in for repair |
Texas
Post Number: 105 Registered: Dec-07
| Posted on Thursday, February 21, 2008 - 10:43 pm: |
what if i bought a low output conv. and hook it up would that tell me if its my output voltage? |
Gold Member Username: Spivey17323
Dunellen,
New jersey
15 inch Alph...
Post Number: 1252 Registered: Jun-07
| Posted on Thursday, February 21, 2008 - 10:45 pm: |
are your subs wired right? |
Texas
Post Number: 106 Registered: Dec-07
| Posted on Thursday, February 21, 2008 - 11:28 pm: |
yea |
