Thread: Powerbass 1000.1d work? |
Bronze Member Username: Justin_13
Post Number: 17 Registered: Feb-08
| Posted on Tuesday, February 19, 2008 - 11:21 am: |
will a powerbass asa 1000.1d amp work with two kicker cvr 12" 4 ohm subs? |
Gold Member Username: 420alldaylong
Post Number: 3293 Registered: Sep-06
| Posted on Wednesday, February 20, 2008 - 12:22 am: |
I seen this setup a couple of times and it sounds good if the subs are in the rite boxes. Wire the subs to 1ohm like this. http://www.the12volt.com/caraudio/woofer_configurations.asp?Q=2&I=42 |
Gold Member Username: N2audio
Lawrence,
Ks
Post Number: 1482 Registered: Mar-04
| Posted on Wednesday, February 20, 2008 - 11:26 am: |
should work real well |
Post Number: 20 Registered: Feb-08
| Posted on Wednesday, February 20, 2008 - 11:28 am: |
even if its only a one channel amp though? |
Gold Member Username: Nd4spd18
Northwest PA
Post Number: 6360 Registered: Jul-06
| Posted on Wednesday, February 20, 2008 - 01:08 pm: |
All subwoofer amps are 1 channel (mono) |
Gold Member Username: Th3pwn3r
Post Number:...
Post Number: 6955 Registered: Jul-06
| Posted on Wednesday, February 20, 2008 - 01:44 pm: |
2-Channel XXV Maxximus 2 x 2000-Watts....RMS @ 4-Ohms 2 x 3500-Watts....RMS @ 2-Ohms 2 x 5000-Watts....RMS @ 1-Ohm 1 x 7000-Watts....Bridged Mono @ 4-Ohms 1 x 10,000-Watts..Bridged Mono @ 2-Ohms |
Northwest PA
Post Number: 6367 Registered: Jul-06
| Posted on Wednesday, February 20, 2008 - 02:26 pm: |
As soon as I posted that I knew someone was going to be a smartass........ figures it would be Rob MOST sub amps are one channel. Nuber of channels has nothing to do with number of subs you have. |
Post Number:...
Post Number: 6964 Registered: Jul-06
| Posted on Wednesday, February 20, 2008 - 02:44 pm: |
^_^ hahaha. I've seen quite a few 2 channel monoblocks. |
Lawrence,
Ks
Post Number: 1483 Registered: Mar-04
| Posted on Wednesday, February 20, 2008 - 04:37 pm: |
FWIW - the maxx is just 2 goliath's in the same chassis - every dual channel mono I know of uses a similar configuration. |
Post Number: 23 Registered: Feb-08
| Posted on Wednesday, February 20, 2008 - 04:41 pm: |
so that amp could power both of them? and could i wire them? |
Post Number: 3297 Registered: Sep-06
| Posted on Wednesday, February 20, 2008 - 05:29 pm: |
Yes wire it to 1ohm just like in the link above I gave you. |
Post Number: 25 Registered: Feb-08
| Posted on Wednesday, February 20, 2008 - 07:05 pm: |
but will the amp hav enough places to wire both of the subs? |
Northwest PA
Post Number: 6372 Registered: Jul-06
| Posted on Wednesday, February 20, 2008 - 07:14 pm: |
LOL it doesn't matter if the amp only has one set of terminals you just put 2 wires in each terminal |
Post Number: 26 Registered: Feb-08
| Posted on Thursday, February 21, 2008 - 11:03 am: |
then im going to get that amp |
Post Number: 3298 Registered: Sep-06
| Posted on Thursday, February 21, 2008 - 07:37 pm: |
Where are you buying the amp from? How much for the amp? |
Post Number: 27 Registered: Feb-08
| Posted on Friday, February 22, 2008 - 11:25 am: |
im going to order it off the internet |
