Home > Message Board > Car Audio > Amplifiers > Archive through February 29, 2008 > Rockford fosgate T5001 bd
Author Thread: Rockford fosgate T5001 bd
Username: Tweidner674
Post Number: 9
does anyone know if this amp can go passed 500w at 1 ohm? the specs on it say it gets 500w at 1 ohm but i've heard that it can be pushed up to 1000w.
Username: Cblaze
Rock island, Tenesssee
Us
Post Number: 1786
mine came with a birth sheet of 969 watts at 1 ohm
Username: Nd4spd18
Northwest PA
Post Number: 6283
Those amps do 700w-1000w it depends on the individual amp
Username: Rtyauch301
Post Number: 209
yea it is possible i have a a t1000 bd in one of my cars and it has a birth sheet of 1698
Post Number: 210
rockford under rates their amps bigtime
Post Number: 10
ok so it sounds like you just get some random number. is there anyway i can make sure to get between 800w and 900w at 1 ohm?
Username: Bonhamd
Northern, Michigan
Post Number: 334
no way to tell unless you buy one from someone that shows you the birthsheet
Post Number: 216
^^^X2
Username: Nd4spd18
Northwest PA
Post Number: 6301
X3
BTW tim, it's only rockfords power series amps that are underrated this way
Username: Davidt487
Texas
Post Number: 99
i bought one 1012 on the birthsheet
Username: Yngve
Ksund, Møre og Romsdal
Norway
The power kable, and battery you run your amp on, is what gives you the 1ohm power. thin kable-smal power, fat kable-more power.
Username: Bonhamd
Northern, Michigan
Post Number: 342
haha^^^^you sir are a dumbass
Username: Bonhamd
Northern, Michigan
Post Number: 343
vc config and subwoofer wiring is how you get a 1 ohm load - not the power and ground wire size
Username: Yngve
Norway
What i ment was you cant get good force throu thin kabels
Username: Yngve
Norway
Post Number: 7
I know how to vire a sub in diferent ohms
Username: Yngve
Norway
Post Number: 10
Sorry my english language is so bad. out of practise
Username: Treez
Post Number: 276
likewise your knowledge... lol j/k
Home > Message Board > Car Audio > Amplifiers > Archive through February 29, 2008 > Rockford fosgate T5001 bd [ « Previous ] [ Next » ]
