Home > Message Board > Car Audio > Security Systems > DEI Hornet Alarm / Remote start
Author Thread: DEI Hornet Alarm / Remote start
Username: Hoppin_poop
Got a quick question... I have installed many DEI alarms/keyless entry systems in the past without any problems. However, this unit seems to send out a constant ground signal on the blue lock/unlock wire. If my memory serves me right, both green and blue lock/unlock wires should not have a positive of negative signal until the keypad is pressed. is this correct? or have things changed?
Relevant Product Info
Post:
Username: Need to Register?
Password: Forgot Password?
Action:
Home > Message Board > Car Audio > Security Systems > DEI Hornet Alarm / Remote start [ « Previous ] [ Next » ]
