Home > Message Board > Car Audio > Amplifiers > Archive through February 29, 2008 > Amp problems
Author Thread: Amp problems
Username: Justin_13
Post Number: 14
i bought a package off ebay that came with two kicker cvr 12" 4 ohm subs and a sound storm FY1802 amp. the amp doesnt push the subs and i can barely hear the bass. i have rewired it all possible ways. does the amp even work with the subs? any suggestions?
Username: Van_man
Boston South, MA
Post Number: 3431
RMS POWER @ 4 OHMS: 325W X 2
That may be your problem.
And the subs, are they dual 4 ohm, single 4 ohm, or dual 2 wired to four?
They shoud be ok with that amp. They are rated for 400wrms. Gain set right? HU settings ok? power ground ok?
Do you have another amp to test the subs with? What box are they in? Do you have a DMM? Are you running them to each channel or bridged?
Username: Justin_13
Post Number: 15
dual 4 ohm...i tried to put them in parrallel but that didnt help...i think im just gna get the powerbass 1000.1d
Username: Van_man
Boston South, MA
Post Number: 3434
well, one last thought. Wire each sub down to 2( Parallel) ohms, then wire them to a 4 ohm load (Serius) bridged on the amp.
Home > Message Board > Car Audio > Amplifiers > Archive through February 29, 2008 > Amp problems [ « Previous ] [ Next » ]
