Thread: Will this amp work with these subs? Need Help Fast!! |
New member Username: Donjuan3316
Post Number: 1 Registered: Feb-08
| Posted on Monday, February 18, 2008 - 04:48 am: |
I'm pretty new to this stuff so if my question is dumb forgive me. I'm going to get a pair of kicker cvr 10's 4 ohm dvc. i'm wondering if a kicker zx10001 class d mono block amp will work with these subs. any suggestions are welcome. |
Gold Member Username: Ctmike
Ct.
Post Number: 5862 Registered: Feb-06
| Posted on Monday, February 18, 2008 - 11:09 am: |
no. you'll want an amp that does 800-1000wrms @ 1ohm. post a budget for an amp. but if you want to get the zx1000 though, get a pair of dual 2ohm cvrs'. |
Gold Member Username: Nd4spd18
Northwest PA
Post Number: 6261 Registered: Jul-06
| Posted on Monday, February 18, 2008 - 01:40 pm: |
^^^^^ exactly |
Post Number: 2 Registered: Feb-08
| Posted on Monday, February 18, 2008 - 02:34 pm: |
well budget on the amp is around $500. i found the zx1000 for $240 tho so thought i would check it out. if anymore suggestions they're welcome. |
Post Number: 3 Registered: Feb-08
| Posted on Monday, February 18, 2008 - 02:35 pm: |
also so if i grab the 2 ohm cvr's that'll work fine with the amp? and is this amp fairly good or should i look for a different one? |
Northwest PA
Post Number: 6267 Registered: Jul-06
| Posted on Monday, February 18, 2008 - 03:42 pm: |
That is a very good amp. Yes, if you get two dual 2 ohm CVRs they will work with that amp. |
Gold Member Username: 04redmach1
Lagrange,
GA
Post Number: 1632 Registered: Mar-06
| Posted on Monday, February 18, 2008 - 08:43 pm: |
Yepers, grab dual 2's, or you can get a Sundown 1000D or a RD 1000.1 for $320 shipped. Kevin |
Silver Member Username: Djl
Post Number: 129 Registered: Sep-06
| Posted on Tuesday, February 19, 2008 - 09:44 am: |
AQ1200D for $249 shipped |
Northwest PA
Post Number: 6311 Registered: Jul-06
| Posted on Tuesday, February 19, 2008 - 11:08 am: |
Damn you guys dropped the price, sweet That amp was a great deal before, now even more so |
