Thread: Will this amp work for me?? |
New member Username: Juancamaney
Post Number: 3 Registered: Jan-08
| Posted on Sunday, February 17, 2008 - 12:10 am: |
I got 2 kickers cvr12 4 ohms dual vc, and i dont know if this amp will work for them, it's a HIFONICS BXi606 Monoblock Amplifier RMS Power Ratings: 1 ohm: 600 watts x 1 channel 2 ohms: 300 watts x 1 channel 4 ohms: 150 watts x 1 channel |
Platinum Member Username: Chaunb3400
Huntsville,
Alabama
U.S.
Post Number: 13848 Registered: Jul-05
| Posted on Sunday, February 17, 2008 - 12:15 am: |
budget?? |
Post Number: 4 Registered: Jan-08
| Posted on Sunday, February 17, 2008 - 12:23 am: |
around $150 bucks, im broke |
Post Number: 6 Registered: Jan-08
| Posted on Sunday, February 17, 2008 - 10:30 am: |
anyone? the amp above will work for my cvr12? |
Gold Member Username: Juliob
Santo Domingo Dominican Re...
Post Number: 5182 Registered: Dec-05
| Posted on Sunday, February 17, 2008 - 11:03 am: |
Not the way you want. I can tell you the best amp you'll find for that amount of money, is not the greatest, but it does the power. http://cgi.ebay.com/Lanzar-OPTI1400D-Mono-Digital-Class-D-Car-Amplifer-AMP_W0QQi temZ130198739383QQihZ003QQcategoryZ39732QQssPageNameZWDVWQQrdZ1QQcmdZViewItem |
