Home > Message Board > Car Audio > Amplifiers > Archive through February 29, 2008 > MMATS DHC3500.05
Author Thread: MMATS DHC3500.05
Username: Tpa954
Hollywood, Florida
U.S.A
Post Number: 219
OK i think i found a amp i like just got my two 13W7 and i think i am going to go with this amp, but when i wire the two subs togther it make it 0.38 OHMS , this amp says it is only stable at 0.50 ohms will this work or not ???? Also how much does this amp actually push since i know everything from mmats is under ratted ???
Username: Cblaze
Rock island, Tenesssee
Us
Post Number: 1750
should work fine,no doubt you are gonna have to get a big alt to stop voltage drops.i would get more oppinnionstho.but from what ive read mmmats amps are tough
Username: Tpa954
Hollywood, Florida
U.S.A
Post Number: 220
I have a 170+ amp im going to need more then that,plus big 3 done and big bat.
Username: Nd4spd18
Northwest PA
Post Number: 6232
I wouldn't do it.
You can wire those subs to 1.5 ohm total. What you should do is look for an amp that does 2500-3000 watts at 1 ohm, and then you would get ~2000w at 1.5, perfect for those subs.
Username: Tpa954
Hollywood, Florida
U.S.A
Post Number: 221
well if i run these at 1.5 it should run around 2350 any way because i herd these amps should push out more then they are rated.
Username: Tpa954
Hollywood, Florida
U.S.A
Post Number: 222
OK so now i got this amp and i am scared to run it at a 0.38 OHM load because it says it is only rated for 0.50. I have seen modification's done to these amps before to run them lower . Were would i go to get this done im just asking for a little extra boost 0.12 is all i need LOL.... ALSO how much does this amp really put out ???
Home > Message Board > Car Audio > Amplifiers > Archive through February 29, 2008 > MMATS DHC3500.05 [ « Previous ] [ Next » ]
