Home > Message Board > Car Audio > Accessories > Output Converter (remote turn on?)...
Author Thread: Output Converter (remote turn on?)
Username: Irmikeee
Bakersfield, CA
ok.
speaker wire (from head unit) goes into the converter. great.
i've got my RCA outs...fine.
but i've got one more brown wire that i believe is the ground, yes?
the thing didnt come with directions (damn)
question: how do i get a remote turn on...?
Relevant Product Info
Username: Ska
Post Number: 456
the balck wire is the grownd. the remote turn on wires are blue and blue with white
Username: Th3pwn3r
Post Number:...
Post Number: 6943
You can also run a wire from your fuse panel and install a switch on the line so you can turn the amp on and off. You can do the same thing by running a power wire up to your driver's seat and putting a switch on it and then sending the wire back into the remote input and you can turn it on and off as you please.
Post:
Username: Need to Register?
Password: Forgot Password?
Action:
Home > Message Board > Car Audio > Accessories > Output Converter (remote turn on?)... [ « Previous ] [ Next » ]
