Thread: Amp Question |
Bronze Member Username: Dirtyd2323
Bp,
Minnesota
U.s.
Post Number: 23 Registered: Jan-08
| Posted on Thursday, February 14, 2008 - 01:50 pm: |
Hey, i got 2 memphis m3 mojos. dual 2 ohm. 1000w rms. Wordering what would be a good choice for an amp. I'll take any advice as long as it isnt from oreos. |
Silver Member Username: Bonhamd
Northern,
Michigan
Post Number: 279 Registered: Nov-07
| Posted on Thursday, February 14, 2008 - 02:36 pm: |
whats your budget? mojos are loud and can take some power maybe a kicker 2500.1...you will def need to upgrade your electrical with a setup like that |
Bp,
Minnesota
U.s.
Post Number: 24 Registered: Jan-08
| Posted on Thursday, February 14, 2008 - 03:13 pm: |
I got about $600-700. With the 2500.1 Would that work with 2 dual 2ohm subs? How would you wire that? |
Northern,
Michigan
Post Number: 283 Registered: Nov-07
| Posted on Thursday, February 14, 2008 - 04:50 pm: |
the kicker zx2500.1 does 2500rms into 2 ohms... 600-700 will cover the cost of the amp alone...do you have the electrical system to support this setup??? http://www.crutchfield.com/learningcenter/car/subwoofers_wiring.html?imageID=2DV C%5F2%2Dohm%5Fmono ^^^ that is how to wire (2) dual 2 ohm subs to a 2 ohm load on the amp |
Bp,
Minnesota
U.s.
Post Number: 25 Registered: Jan-08
| Posted on Thursday, February 14, 2008 - 05:01 pm: |
Well, not at the moment. I am currently setting that up. I'm on the phone with ohio gen right now, so hopefully soon. Thanks though man. |
Northern,
Michigan
Post Number: 286 Registered: Nov-07
| Posted on Thursday, February 14, 2008 - 05:43 pm: |
yessir |
