Thread: 800-1000 watt amp @ 1 ohm |
New member Username: Justin_13
Post Number: 9 Registered: Feb-08
| Posted on Thursday, February 14, 2008 - 11:08 am: |
what amp should i use for an amp that does 800-1000 watts @ 1 ohm |
Post Number: 10 Registered: Feb-08
| Posted on Thursday, February 14, 2008 - 11:25 am: |
and the subs are 4 ohm so can they be wired at a 1 ohm load? |
Gold Member Username: N2audio
Lawrence,
Ks
Post Number: 1479 Registered: Mar-04
| Posted on Thursday, February 14, 2008 - 11:30 am: |
do you have a budget in mind? you can spend anywhere from $150 on a refurb to $700 on a Focal. |
Silver Member Username: Bonhamd
Northern,
Michigan
Post Number: 276 Registered: Nov-07
| Posted on Thursday, February 14, 2008 - 12:47 pm: |
justin - this is a good amp for the price and you will probably be able to get it cheap. http://cgi.ebay.com/ebaymotors/Diamond-D3-800-1-In-original-box-Class-D-JL-D6-D9 _W0QQcmdZViewItemQQcategoryZ38638QQihZ019QQitemZ290205134205QQrdZ1QQsspagenameZW DVW |
Silver Member Username: Snowball123
West Allis,
WI
United States
Post Number: 293 Registered: Oct-07
| Posted on Thursday, February 14, 2008 - 06:42 pm: |
what about a rockford T5001BD? |
Bronze Member Username: Justin_13
Post Number: 11 Registered: Feb-08
| Posted on Thursday, February 14, 2008 - 06:50 pm: |
ya but i jst looked at the manual and it says it cant be set up to a 1 ohm load...it says it can be wired to run at a 2 ohm or 8 ohm load bcuz there is two subs so i dont know if it will work |
Northern,
Michigan
Post Number: 291 Registered: Nov-07
| Posted on Thursday, February 14, 2008 - 06:54 pm: |
justin - look at your voice coil on your sub and read it...how many subs do you have and what is the voice coil configuration? the manual is most likely standard so they dont have to print out seperate manuals for numerous types of vc configs. |
Post Number: 13 Registered: Feb-08
| Posted on Thursday, February 14, 2008 - 07:21 pm: |
they are 4 ohm nd i have two of them...the most i can spend is 300 |
Northern,
Michigan
Post Number: 298 Registered: Nov-07
| Posted on Thursday, February 14, 2008 - 07:40 pm: |
check your other thread... |
Silver Member Username: 2pacalypse1971
Sandusky,
Oh
Post Number: 479 Registered: Jul-05
| Posted on Thursday, February 14, 2008 - 11:50 pm: |
i'll let ya get my mbquart RAA 1000 for 205 shipped to you door, 1000 watts at one ohm, very good condition, does rated power and everything, hit me up at betterdayz728@bex.net if your interested |
