Thread: Radio reception on DEH-P690UB |
Bronze Member Username: Bradrgilmann
Post Number: 18 Registered: Dec-07
| Posted on Wednesday, February 13, 2008 - 11:21 pm: |
I just changed my stock radio in my 06 altima to a pioneer DEH-P690UB head unit. The radio reception is now awful. If I move the wires with my hand it comes in and out and if I put it in the best reception spot is goes bad again after driving awhile. What can I do to help it. I need the radio. My stock radio had great reception. Thanks Brad |
Relevant Product Info
Bronze Member Username: Ewok
Fairbanks,
Alaska
U.S.A.
Post Number: 43 Registered: Jan-08
| Posted on Thursday, February 14, 2008 - 05:02 am: |
antenna |
Post Number: 19 Registered: Dec-07
| Posted on Saturday, February 16, 2008 - 12:10 am: |
its an internal antenna |
Post Number: 20 Registered: Dec-07
| Posted on Saturday, February 16, 2008 - 12:12 am: |
its an internal antenna in the car. So how do I change it or what else can i do? Thanks brad |
Platinum Member Username: Project6
Post Number: 15088 Registered: Dec-03
| Posted on Sunday, February 17, 2008 - 11:07 am: |
The internal antenna of Nissan Altimas are powered and boosted. You need to get an antenna adapter. You can't just connect the antenna lead without the power supply to the antenna booster. |
Post Number: 21 Registered: Dec-07
| Posted on Sunday, February 17, 2008 - 11:58 pm: |
Do you know where I can buy that and how does it work I plug it into the head unit then the attenna or what? Thanks a lot Brad |
Post Number: 15095 Registered: Dec-03
| Posted on Monday, February 18, 2008 - 03:03 am: |
Best Buy, or Fry's or any decent car audio shop should carry it. |
Post Number: 22 Registered: Dec-07
| Posted on Monday, February 18, 2008 - 08:46 pm: |
Is this what I need? Why Do I need that though. The factory antenna plugs into my head unit now. I am confussed because I have always had after market radios and never had to buy one of these and got great reception. http://cgi.ebay.com/87-06-NISSAN-ALTIMA-INFINITI-RADIO-ANTENNA-ADAPTOR-NEW_W0QQi temZ320218079408QQihZ011QQcategoryZ32812QQssPageNameZWDVWQQrdZ1QQcmdZViewItem |
Post Number: 15103 Registered: Dec-03
| Posted on Monday, February 18, 2008 - 09:10 pm: |
The antenna adapter will have a blue lead wire and the will connect to the blue and white power antenna wire output of the stereo you will be using. This will supply power to the altima's internal antenna. |
Post Number: 23 Registered: Dec-07
| Posted on Tuesday, February 19, 2008 - 03:56 pm: |
If you find one online for a 2006 altima can you please send me the link. Sorry for the trouble, but I can't find one online. Thanks a lot for the help Thanks Brad |
Post Number: 15116 Registered: Dec-03
| Posted on Tuesday, February 19, 2008 - 08:27 pm: |
http://www.tss-radio.com/nissan-antenna-adapter-kit-p-4070.html |
Post Number: 15117 Registered: Dec-03
| Posted on Tuesday, February 19, 2008 - 08:36 pm: |
Depending on the type of connector you had with the stock radio, try this one too. I know it does not say you need it, but the problem is there. What these kit makers fail to realize is that they assume that an 06 has an external antenna. More often than not, an internal antenna needs a 12v power supply. http://www.crutchfield.com/S-n6XRYvt2kZ0/App/Product/Item/Main.aspx?I=12040NI22 |
Post Number: 25 Registered: Dec-07
| Posted on Tuesday, February 19, 2008 - 11:35 pm: |
Thanks. I found this one on ebay that looks similar for a lot cheaper. If not will any on ebay work there all like $5 compared to $30+shipping. Where would that one plug into though on a new radio. I don't have any spot for that plug on the second link. http://cgi.ebay.com/ANTENNA-ADAPTER-NISSAN-ANT03_W0QQitemZ140186945662QQihZ004QQ categoryZ32809QQrdZ1QQssPageNameZWD1VQQ_trksidZp1638.m118.l1247QQcmdZViewItem |
Post Number: 15131 Registered: Dec-03
| Posted on Tuesday, February 19, 2008 - 11:51 pm: |
Sorry Brad, I can't tell you for sure about ebay stuff. You don't have a Fry's, Best Buy or Circuit City around your area? |
Post Number: 26 Registered: Dec-07
| Posted on Wednesday, February 20, 2008 - 03:49 pm: |
Yeah I do about 50 miles away. When I get a chance Ill go down there. Thanks a lot Brad |
Post Number: 15146 Registered: Dec-03
| Posted on Thursday, February 21, 2008 - 01:15 am: |
Brad, I just bought that headunit for my son's SUV, how do you like it? |
Post Number: 27 Registered: Dec-07
| Posted on Thursday, February 21, 2008 - 07:02 pm: |
I love it other then the radio reception. It is great with an ipod. If I can fix this reception, it will be my favorite head unit yet. Thanks Brad |
Fairbanks,
Alaska
U.S.A.
Post Number: 83 Registered: Jan-08
| Posted on Friday, February 22, 2008 - 03:29 pm: |
i have 1 too, and its user friendly, great feature and sq |
New member Username: Croket
Post Number: 1 Registered: Apr-08
| Posted on Thursday, April 10, 2008 - 07:21 pm: |
Hello Brad I was just wondering if you ever fixed that reception problem, I just installed an aftermarket head unit in my 06 Altima and I'm also having the same exact problem. |
