Home > Message Board > Car Audio > Amplifiers > Archive through February 29, 2008 > What specs for soundstream subs?
Author Thread: What specs for soundstream subs?
Username: Yungt
Rome
Italy
I just got 2 12" (350WRMS picasso) soundstream subs.
What amp(or amp specifications) would you recommend would work best on thees subs.
I'm looking for somthing resonably priced.
And also wanted to know what is the difference between a 4ch, a 2ch and a mono amp when having 2 subs connected? which is the best option or is it the same?
thanks!
Username: Yungt
Rome
Italy
And how are ample subs?
Username: Cblaze
Rock island, Tenesssee
Us
Post Number: 1727
u want mono amp for subs.what voice coils they got also?
Username: Yungt
Rome
Italy
Post Number: 9
Its a dual 4Ohm
here are the specs:
http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=16598
Username: Cblaze
Us
Post Number: 1737
get a mono amp that will give u 7-800 watts at 1 ohm.tell me how much cash u got and i can help u out
Username: N2audio
Lawrence, Ks
Post Number: 1478
a 2 ch that bridges to ~800w at 4 ohms would work fine too. The advantage a mono would give you is that most of them are class D, which makes them more efficient than a typical 2 channel that is class a/b.
The Hifonics bxi1206d will give you around 1000w at 1 ohm - you can find them for around 200.
The Lanzar Opti1400D would work well - it's $219 shipped at allaudioexpo.com
Here's a decent 2 ch that should give you around 700w - $180 shipped -- http://www.sonicelectronix.com/item_9177_Clif+Designs+CD6.2LE.html
If you go much cheaper than that you really start rolling the dice on reliability.
Username: Yungt
Rome
Italy
Post Number: 10
thanks i will have a look at them
well i have about $200 i can spend on an amp
Home > Message Board > Car Audio > Amplifiers > Archive through February 29, 2008 > What specs for soundstream subs? [ « Previous ] [ Next » ]
