Home > Message Board > Car Audio > Amplifiers > Archive through February 29, 2008 > Why does my amp shut off a mid volume
Author Thread: Why does my amp shut off a mid volume
Username: Mostly_highs
I have a sony 600w amp run with the hookup kit from the local audio store it is a 4 channel with 2 channels powering 4 6inch speakers and the other 2 channels running a 10' sub and a pa when the amp shuts down it isnt hot to the touch could it not have big enough wire powering it it is grounded under a bolt on the frame
Username: Mixmastaspig
Canada, Canada
Post Number: 1484
You are running it as some weird ohm load that it most likely can't handle. Get a class D mono amp for your sub as running it off your 4 channel isn't reccomended.
Username: Stateprop486
PA
Post Number: 388
thats y u dont use sony amps...and its not a good idea to hook up ur speakers to the same amp as your sub... lol
Username: Nd4spd18
Northwest PA
Post Number: 6144
i took off the sub but it still shuts off the 6inch i think are 8 ohm and they are wired in parallel so the resistence should only be 4 ohm right not to bad of a load gain isnt set but half way up
PA
Post Number: 399
like i said b4.."thats y u dont use sony amps" there amps suck bro.
thanks for ur help im selling the sony and getting another amp any good brands for less then 300 in around 1000 watts or so
PA
Post Number: 432
zx1000.1 does 1000 @ 2ohms but they are underated and will do more watts, on ebay prob 250 r so shipped. i got mine off ebay refurb and it works great still running strong after 6 months. dnt forget dont use the same amp u use to power ur subs to power ur speakers too. that is an bad idea.
Home > Message Board > Car Audio > Amplifiers > Archive through February 29, 2008 > Why does my amp shut off a mid volume [ « Previous ] [ Next » ]
