Thread: Amp for two cvr 12s |
New member Username: Justin_13
Post Number: 1 Registered: Feb-08
| Posted on Tuesday, February 12, 2008 - 11:17 am: |
what is the best amp for two Kicker Comp-CVR 12" Subwoofers: Specifications: Injection-molded Double-stitched, foam-ribbed rubber surround Frequency response: 25-500 Hz Power handling: 50-400 watts RMS Peak power: 800 watts Impedance: 2 or 4 Ohms DVC Dual Voice Coil Sensitivity: 86.7 dB Top-mount depth: 6-3/16" Sealed box volume: 1.0-4.6 cu. ft. Ported box volume: 1.75-2.25 cu. ft. |
Silver Member Username: Bonhamd
Northern,
Michigan
Post Number: 234 Registered: Nov-07
| Posted on Tuesday, February 12, 2008 - 01:31 pm: |
budget? |
Gold Member Username: N2audio
Lawrence,
Ks
Post Number: 1477 Registered: Mar-04
| Posted on Tuesday, February 12, 2008 - 04:44 pm: |
and dvc 2 or 4? |
Post Number: 2 Registered: Feb-08
| Posted on Tuesday, February 12, 2008 - 04:45 pm: |
somewhere around 300...i was thinkin about the kicker ZX 750 but i didnt kno if that would push them |
Silver Member Username: Somedonniedude
Illinois
United States
Post Number: 932 Registered: May-07
| Posted on Tuesday, February 12, 2008 - 05:25 pm: |
A zx750.1 would push them nicly, as long as they are Dual 2 ohm subs. |
Post Number: 3 Registered: Feb-08
| Posted on Tuesday, February 12, 2008 - 08:58 pm: |
i think they are 4 ohms. why cant they be 4 |
Bronze Member Username: Schinner
Post Number: 66 Registered: May-07
| Posted on Wednesday, February 13, 2008 - 12:28 am: |
i have a zx 750.1 birthsheet has it pushing much more than 750 rms....around 850-900rms if i remember correctly, it should push those 12 cvrs and yes if they are the dvc 4 ohms you wont be able to wire them to a 2 ohm load....you wont be able to use the full power of the amp. |
Platinum Member Username: Chaunb3400
Huntsville,
Alabama
U.S.
Post Number: 13809 Registered: Jul-05
| Posted on Wednesday, February 13, 2008 - 02:32 am: |
http://www.the12volt.com/caraudio/woofer_configurations.asp |
Post Number: 4 Registered: Feb-08
| Posted on Wednesday, February 13, 2008 - 10:53 am: |
what do i get if they are 4 ohms then |
Northern,
Michigan
Post Number: 258 Registered: Nov-07
| Posted on Wednesday, February 13, 2008 - 12:02 pm: |
an amp that will do around 800-1000rms into 1 ohm. you can probably get this for a good price... http://cgi.ebay.com/ebaymotors/Diamond-D3-800-1-In-original-box-Class-D-JL-D6-D9 _W0QQcmdZViewItemQQcategoryZ38638QQihZ019QQitemZ290205134205QQrdZ1QQsspagenameZW DVW or sonic electronix has it for $240. but there are plenty of amps you can get in the price range you have posted. I am sure these guys can come up with a good idea for you. |
Post Number: 5 Registered: Feb-08
| Posted on Wednesday, February 13, 2008 - 07:03 pm: |
the manual says it can be 2 or 4 |
Gold Member Username: •cam•
BC
Post Number: 1920 Registered: Nov-06
| Posted on Wednesday, February 13, 2008 - 07:05 pm: |
That's because you can get them in either dual 4 ohm coils or dual 2 ohm coils. We need to know which coils you have. |
Silver Member Username: Drant19
DUB-C,
TX
Post Number: 340 Registered: Aug-07
| Posted on Wednesday, February 13, 2008 - 07:21 pm: |
if you have ONE dual4ohm sub, it can be wired to 2, 4, or 8ohms. but since u have TWO dual4ohm subs you can wire them to 1ohm and 4ohm. its easier to get more power at 1ohm, so u want to look for an amp that does 800-1000rms at 1ohm |
Post Number: 6 Registered: Feb-08
| Posted on Wednesday, February 13, 2008 - 10:23 pm: |
so the 1 ohm works with 4 ohms |
Northern,
Michigan
Post Number: 271 Registered: Nov-07
| Posted on Wednesday, February 13, 2008 - 11:17 pm: |
(2)dual 4 ohm subs can be wired to 1 ohm. Get an amp that supplies 800-1000 watts RMS into 1 ohm. |
Post Number: 8 Registered: Feb-08
| Posted on Thursday, February 14, 2008 - 10:57 am: |
alright thanks |
Bronze Member Username: Justin_13
Post Number: 12 Registered: Feb-08
| Posted on Thursday, February 14, 2008 - 07:15 pm: |
so since i hav 2 of them they cant be wired to a 2 ohm load because the manual says one sub would be able to... |
Gold Member Username: Ctmike
Ct.
Post Number: 5859 Registered: Feb-06
| Posted on Thursday, February 14, 2008 - 07:27 pm: |
yes, one sub can be wired to 2ohm. a pair of dual 4ohm subs though can't. as explained already. go to www.jlaudio.com, they have a wiring wizard for you to use. just get an amp that'll do 800-1000wrms at 1ohm and wire the pair to 1ohm and you'll be set. personally, i'd get a sundown sae1000d. $300 shipped from dealer, great little amp, nice warranty and customer service. can't go wrong with it. order here if interested, www.kluvkustoms.com. very nice customer service there and fast shipping. |
Northern,
Michigan
Post Number: 297 Registered: Nov-07
| Posted on Thursday, February 14, 2008 - 07:36 pm: |
here- http://www.the12volt.com/caraudio/woofer_configurations.asp?Q=2&I=42 those are your options |
