Thread: Alpine MRP M850 Sub Amp any good ? |
New member Username: Rickvl
Vancouver Canada
Post Number: 1 Registered: Feb-08
| Posted on Monday, February 11, 2008 - 06:43 pm: |
Alpine MRP M850 Sub Amp any good ? What Sub would go good with it? Thanks |
Silver Member Username: Bonhamd
Northern,
Michigan
Post Number: 226 Registered: Nov-07
| Posted on Monday, February 11, 2008 - 06:49 pm: |
alpine makes nice equipment...what are you looking to acheive? |
Silver Member Username: Drant19
DUB-C,
TX
Post Number: 338 Registered: Aug-07
| Posted on Monday, February 11, 2008 - 06:50 pm: |
budget? what do u want? SQ, SQL, SPL? |
Vancouver Canada
Post Number: 2 Registered: Feb-08
| Posted on Tuesday, February 12, 2008 - 12:10 am: |
Ok I bought the amp and 4g wire kit,installed it today,this amp is very powerful,but my old 10" Infinity Reference 1030w in a bassworks ported box just is not cutting it anymore.I want more bass and louder, at 2ohms the amp puts out 800 watts and puts out 500 at 4 ohms.Is this possible on a reasonable amount of cash. Thanks. |
Vancouver Canada
Post Number: 4 Registered: Feb-08
| Posted on Tuesday, February 12, 2008 - 10:50 pm: |
Could I replace the 10" sub I have now and use the same box and get better results or should I go with bigger sub 12" |
New member Username: Tweidner674
| Posted on Tuesday, February 12, 2008 - 11:13 pm: |
i'm actually thinking about buying this sub. ive been getting different feedback from different people about it tho. i know it gets 800w at 2 ohms. but the 2 subs i already bought (kicker cvr 12s) have each have dual 4 ohms. is it possible to wire the two of those down to two ohms to be compatible with this amp? most people have said yes but i just want to be sure about it. also: here's the link to it in case anyone needs to see it http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=17565 |
Vancouver Canada
Post Number: 5 Registered: Feb-08
| Posted on Wednesday, February 13, 2008 - 12:37 am: |
I Have this amp and it is very powerful and clean sounding I'm very happy with it. and here is a link to help you with your sub wiring. http://www.crutchfield.com/learningcenter/car/subwoofers_wiring.html |
| Posted on Thursday, February 14, 2008 - 04:26 pm: |
that sort of helps but the diagram for a mono amp with two 4 ohm dvc subs says that there's a 4 ohm load on the amp. would i be able to wire the subs down to 2 ohms to get more out of the amp? |
Northern,
Michigan
Post Number: 293 Registered: Nov-07
| Posted on Thursday, February 14, 2008 - 07:07 pm: |
richard - you can probably get louder than the infinity 10 for a reasonable price while using the same amp...a lot of it depends on how much space you have for a box and your budget is also a factor. tim - two dual 4 ohm subs can be wired to 4 ohms or 1 ohm. that amp would not be a good choice because you could only put 500 watts to the pair which is not enough. you should probably look for an amp that will put out 800-1000 rms into 1 ohm. |
