Home > Message Board > Car Audio > Accessories > Help installing a dixie horn
Author Thread: Help installing a dixie horn
Username: Firefighter23
need help on installing a dixie horn on a 2000 ford expedition. particularly on how to hook it up to the 12 volt battery
-thanks!
Relevant Product Info
Username: Jtown
Team RD, Texas
Post Number: 2101
yeeha!
Username: Adddisorder
Palm Beach, Florida
Post Number: 5906
what kind of horn is it post a link or a picture with everything.
does it have a compressor?
Palm Beach, Florida
Post Number: 5931
looks like you need to hook the relay up to the compressor and use your stock horn wire to tirgger the relay. then just hook the tubing up to the horns. the12volt.com has a diagram to show you how to hook up a relay.
thanks!
Post:
Username: Need to Register?
Password: Forgot Password?
Action:
Home > Message Board > Car Audio > Accessories > Help installing a dixie horn [ « Previous ] [ Next » ]
