Thread: Wiring problems |
New member Username: Burtontd
Kansas
Post Number: 4 Registered: Feb-08
| Posted on Monday, February 11, 2008 - 04:49 pm: |
first off i am new to the game. i am currently running a 300w audiovox off a pioneer head with 2 600w 10" kicker comps. i was given a kole q4-960 and thought this hase to be better than what i got. hooked it up but the power light turns red and says protection. what am i doing wrong? for now i will brave the frigid temps and try again.any advice is appreciated! thanx |
Silver Member Username: Ska
Post Number: 392 Registered: Jan-08
| Posted on Monday, February 11, 2008 - 05:17 pm: |
that amp might not be able to handle the ohm load your giving it... |
Silver Member Username: Wylie_coyote
Post Number: 175 Registered: Apr-07
| Posted on Tuesday, February 12, 2008 - 08:40 am: |
you should also check that it has been connected up the right way. Check all the wiring, especially the Ground and remote. 8/10 times its the wiring which is causing the protection light to come on |
New member Username: Mostly_highs
Post Number: 5 Registered: Feb-08
| Posted on Tuesday, February 12, 2008 - 08:09 pm: |
shorten ground wire???? |
Gold Member Username: Van_man
Boston South,
MA
Post Number: 3400 Registered: Mar-06
| Posted on Tuesday, February 12, 2008 - 11:09 pm: |
how are you wirering it? Whats the voice coils on the subs? I assume you have 4 ohm dvc subs, each wired down to a 2 ohm load, bridged on each channel? Output 100 x 4 at 4 ohms RMS 125 x 4 at 2 ohms RMS 250 x 2 Watts at Mono My quess is that you are running it too low. Try running 1 sub to channel 1, and 1 sub to channel 2. Leave 3-4 empty. does it come on? If so, then that amp can only be bridged at 4 ohms. Also check the ground connections. if its lighting, its got power. |
New member Username: Chrisryanbailey
Post Number: 1 Registered: Feb-08
| Posted on Saturday, February 16, 2008 - 10:48 am: |
i got my 3 jl subs running off a 900watt class d kicker amp and i just purchased a pair of kicker ks20 tweeters witch i am going 2 have hooked up 2 a rockfordfausgate p.450 amp and i just wanted 2 know if u can hook up the rockford amp with out running anything from the deck and just bridging or splitting from my other amp????????? does any of that seem possible>haha |
Silver Member Username: Waresgaragestereo
Fort Valley,
GA
United States
Post Number: 142 Registered: Jan-08
| Posted on Saturday, February 16, 2008 - 11:21 pm: |
what do you mean bridge off of the other amp? if you mean what i think you mean, the answers no. |
