Thread: NEED HELP WITH CAR AUDIO |
New member Username: Mikeyruubs
Post Number: 2 Registered: Feb-08
| Posted on Monday, February 11, 2008 - 11:32 am: |
so i need some help... im putting a 3600W system in my 98 acura CL. I know most batteries put out 1000W so how can i get at least 3000W? im gonna get a amp but i still need the power. Theres no room for more alternators or batteries so i need somin else. capacitors?? mabey? |
Relevant Product Info
Silver Member Username: Waresgaragestereo
Fort Valley,
GA
United States
Post Number: 124 Registered: Jan-08
| Posted on Monday, February 11, 2008 - 12:32 pm: |
a capacitor is nothing but a bandaid. for an amp that big, you need a High Output alternator. get a 200amp alt and replace your factory alt with this and do the big 3 upgrade. then for the amp power wire, get some 1/0 welding cable and a 300 amp fuse and run from the battery to the amp. there is no way around going with a ho alt and the big 3 upgrade. Capacitors are no good. PERIOD. www.db-starter-alternator.com this is where you can find some ho alts at. make sure you get high strand count wire, its more flexable than low strand wire. http://www.knukonceptz.com/ this is where you can pick up the wire at. |
Gold Member Username: Th3pwn3r
Post Number:...
Post Number: 6813 Registered: Jul-06
| Posted on Monday, February 11, 2008 - 12:39 pm: |
" Capacitors are no good. PERIOD" Some people are so misinformed. Do you realize that there are capacitors in amplifiers and in lots of things? They serve their uses and when used properly can be helpful. This is not one of those instances. To the original poser; you need a high output alternator and the proper wiring(Big 3) to fix your issues to provide sufficient power for that type of system. |
Fort Valley,
GA
United States
Post Number: 127 Registered: Jan-08
| Posted on Monday, February 11, 2008 - 12:47 pm: |
"This is not one of those instances. To the original poser; you need a high output alternator and the proper wiring(Big 3) to fix your issues to provide sufficient power for that type of system." thats what i said.in line caps are no good. i didn't say anything about caps inside stuff. |
Post Number:...
Post Number: 6822 Registered: Jul-06
| Posted on Monday, February 11, 2008 - 01:55 pm: |
"Capacitors are no good. PERIOD" That's exactly what you said. There's no debate about it. |
Platinum Member Username: Bestmankind
Los Angeles,
CA
Post Number: 18084 Registered: Oct-05
| Posted on Monday, February 11, 2008 - 07:26 pm: |
rob you said "to the original poser" lol. poser? |
Silver Member Username: Stateprop486
PA
Post Number: 390 Registered: Jan-08
| Posted on Tuesday, February 12, 2008 - 07:13 pm: |
lol we know what he ment. "poster" jus a mistype. |
Post Number:...
Post Number: 6863 Registered: Jul-06
| Posted on Friday, February 15, 2008 - 11:02 am: |
"rob you said "to the original poser" lol. poser?" Yea, I would have edited the post but it was too late because I had too many posts after that one. |
