Thread: Decided on alpine. |
Bronze Member Username: Dupe112309
Post Number: 31 Registered: Feb-08
| Posted on Sunday, February 10, 2008 - 08:19 pm: |
type r components for the front and type r for rear too...fronts put out 90w and rears 100w rms. would the pdx 4.100 be a good setup altogether? along with a 16 ga amp kit |
Silver Member Username: Philly306
I get higher golf scor...,
North carolina
Post Number: 845 Registered: Apr-07
| Posted on Sunday, February 10, 2008 - 08:25 pm: |
16 ga amp kit? do they really make those? theres no way yea that should be fine but u need something like a 8 gauge kit and speakers are rated for power handling, they don't "put out watts" |
Post Number: 32 Registered: Feb-08
| Posted on Sunday, February 10, 2008 - 08:56 pm: |
ok the fronts are rated at 90 and the rears 100 sorry phil. but 8 ga will be fine? |
Gold Member Username: Bnd_rulez
Phoenix,
AZ
Post Number: 1449 Registered: Mar-05
| Posted on Monday, February 11, 2008 - 09:44 am: |
8 gauge power and ground wire will work perfectly. The you can use some 16 gauge speaker wire to actually hook up to the speakers from the amp. |
