Home > Message Board > Car Audio > Amplifiers > Archive through February 29, 2008 > JL Audio Or Mmats?
Author Thread: JL Audio Or Mmats?
Username: Oldskoolquake
North, Florida
U.S.A
Which amp(s) would Best fit these setup I'm wanting accomplish. I have two JL Audio 13.5s. So would I need 1 mmats d3500.05 or 2 mmats 1600.1 or 2 JL Audio 1000.1? I'm trying to achieve that "wow" factor. Money Is Not An Issue. Also, the car is a '03 Impala. Thanks All. P.S. I already have a 1400.1 old model mmats, so I guess you can see my love with mmats. Yeah, I'm from Florida LOL
Username: Chaunb3400
Huntsville, Alabama
U.S.
Post Number: 13770
im not sure what the wow factor is to you, so i really couldnt tell you, but i would get the JL amps..do you want the matching amps WOW!!! or the WOW you spend alot on your setup??
North, Florida
U.S.A
Wow as in sound, I never show my setup so matching means nothing to me.
Huntsville, Alabama
U.S.
Post Number: 13775
are they w6's or w7's?? because for the money..U could definitely get a wow factor with something else
North, Florida
U.S.A
JL Audio 13w7's Max Watts 4000. http://mobile.jlaudio.com/products_subs.php?series_id=10
Username: 420alldaylong
Post Number: 3255
Well the way they have to be wired it looks to be 2 JL 1000/1.
There are two reason I don't like JL AUDIO (1) because of PRICE and (2) is the way the ohm is on there subs there basically forcing you to put there amps on there subs.
Username: Bnd_rulez
Phoenix, AZ
Post Number: 1448
Yeah, why the h3ll can't a 12W6 be dual 2 ohm? They do make good stuff though.
North, Florida
U.S.A
Thanks 4 the advice,all. That one thing was on my mind because it seems that everyone I've talked to who has these subs have the jl audio 1000/1 on them. Appreciate the clarification.
Username: Drant19
DUB-C, TX
Post Number: 337
2 of these would cost less than the JLs and it does 1200rms 1-4ohms
http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=471
North, Florida
U.S.A
Thanks Abarca for the link. So it is set that mmats amps are no good for the jl audio's. Not the 3500/1 or the 3500/.05 or two of the 1600/1?
Username: Juliob
Santo Domingo
Dominican Re...
Post Number: 5176
they're good. The thing is that jls 1000/1 was made to push those subs.
Los Angeles, CA
Post Number: 18081
go with the mmats
mmats>>>>jl audio.....any fukkking day of the week.
Username: The12voltrep
Palm Beach, FL
Post Number: 19
Chad=Correct!
Username: Loc_out
Santa Ana, Ca
Resonant Eng...
Post Number: 1709
WOW Chad WOW. All i have to say this is a WOW thread.
Username: N2audio
Lawrence, Ks
Post Number: 1480
mmats, because it's not JL :-)
JL doesn't "wow" me at all. When I see a bunch of JL gear it's more of a..."great - you have money and went with JL, shocker."
At least Mmats is a little more exclusive.
Home > Message Board > Car Audio > Amplifiers > Archive through February 29, 2008 > JL Audio Or Mmats? [ « Previous ] [ Next » ]
