Home > Message Board > Car Audio > Head Units > Need help with system remote wiring o...
Author Thread: Need help with system remote wiring on my hu
Username: Zester
Gardena , California
Post Number: 36
i like to connect an amp to my hu, from the amp i already have the ground and battery wire connected to the car, but i dont know what kind of wire do i need for the remote from amp to the hu? can i use any wire for that? does it have to be a blue and white color wire?
Relevant Product Info
Username: Waresgaragestereo
Fort Valley, GA
United States
Post Number: 114
wire is wire. no matter the color. its easier to identify the remote if its blue. get some 14 or 12 GA wire and run it from the HU to the amp. ther you have it!
Username: Nd4spd18
Northwest PA
Post Number: 6065
What is it with you people thinking you need huge wire for the remote........
http://forum.ecoustics.com/bbs/messages/4/445811.html
And don't make multiple threads
Username: Ewok
Fairbanks, Alaska
U.S.A.
Post Number: 27
i made 2 threads about the remote wire things, because i just wanted to make sure some1 would see it right away and i would get multipe advices. buy thanks again
Username: Ewok
Fairbanks, Alaska
U.S.A.
Post Number: 28
sorry man, im not as good as you guys, im just a beginner in car audio tuning
Username: Typejl
Hopkinton, Iowa
United states
Post Number: 19
you dont need that big of a dam wire for your remote 12 or 14 gauge.. thats retarded
Post:
Username: Need to Register?
Password: Forgot Password?
Action:
Home > Message Board > Car Audio > Head Units > Need help with system remote wiring o... [ « Previous ] [ Next » ]
