Thread: Wiring from a hi-lo converter to the amp... |
Bronze Member Username: Gustavocordero777
Orlando,
FL
Post Number: 22 Registered: Dec-07
| Posted on Friday, February 08, 2008 - 01:33 pm: |
im wondering what is the best way to fix this issue: im using an adapter to convert my factory HU output to four rca's males(front L&R and rear L&R). then i have my standard rca cable from my 4ch wiring kit to run from the converter to the amp. the issue is between the converter and the cable, they are all male rca's. what is normally used to fix this? i was thinking female to female adapters or something.... THANKS |
Relevant Product Info
Silver Member Username: Waresgaragestereo
Fort Valley,
GA
United States
Post Number: 115 Registered: Jan-08
| Posted on Friday, February 08, 2008 - 03:45 pm: |
go to some plave like radio shack and get a connector that is for rca. tell them you have 2 rca jacks that need to be connected and that both ends are male. in other words, you want a female rca connector. |
Orlando,
FL
Post Number: 23 Registered: Dec-07
| Posted on Friday, February 08, 2008 - 04:44 pm: |
are you saying female to female rca connector? thats what i thought... |
Fort Valley,
GA
United States
Post Number: 118 Registered: Jan-08
| Posted on Friday, February 08, 2008 - 09:33 pm: |
this.
Orlando,
FL
Post Number: 24 Registered: Dec-07
| Posted on Monday, February 11, 2008 - 09:56 am: |
perfect. thats what i thought. thanks for confirming!! I appreciate it. |
