Home > Message Board > Car Audio > Accessories > Wiring from a hi-lo converter to the ...
Author Thread: Wiring from a hi-lo converter to the amp...
Username: Gustavocordero777
Orlando, FL
Post Number: 21
im wondering what is the best way to fix this issue:
im using an adapter to convert my factory HU output to four rca's males(front L&R and rear L&R). then i have my standard rca cable from my 4ch wiring kit to run from the converter to the amp. the issue is between the converter and the cable, they are all male rca's. what is normally used to fix this? i was thinking female to female adapters or something.... THANKS
Relevant Product Info
Post:
Username: Need to Register?
Password: Forgot Password?
Action:
Home > Message Board > Car Audio > Accessories > Wiring from a hi-lo converter to the ... [ « Previous ] [ Next » ]
