Thread: Crunch gp2350 1400 w amp--help |
New member Username: Grat
Post Number: 1 Registered: Feb-08
| Posted on Monday, February 04, 2008 - 08:56 pm: |
I have installed a Crunch GP2350 1400W amp but it does not seem to turn on. The power light does not come on. I have 12 volts across the amp power lead and ground. When I test the power lead and remote lead the power light flickers. I installed it on a 97 grand cherokee . I have a sony unit without RCA outputs. used high input adapter. My remote lead is connected to the atenna lead on the radio. any suggestions or alternatives would be appreciated. |
Post Number: 2 Registered: Feb-08
| Posted on Wednesday, February 06, 2008 - 06:30 pm: |
I need help with my amp.. |
New member Username: Mostly_highs
Post Number: 7 Registered: Feb-08
| Posted on Thursday, February 14, 2008 - 10:19 pm: |
connect remote wire to the blue and white wire the atenna wire probuly cant supply enough power to turn on that large of an amp |
Silver Member Username: Santa_fe
02 Hyundia Santa Fe,
120.3 db not...
Post Number: 489 Registered: Jul-07
| Posted on Saturday, February 16, 2008 - 12:29 pm: |
wrong, run the remote wire form ur fuse box....on a fuse that trunbs on when ur car starts....like the d-clock or radio then remote isent tell the amp to trun on when its ffrun from teh pwr antenna |
Gold Member Username: Nd4spd18
Northwest PA
Post Number: 6233 Registered: Jul-06
| Posted on Sunday, February 17, 2008 - 05:17 pm: |
No, use the remote wire at the HU, not the power antenna wire. The HU has a wire for this you don't have to use the fuse box. |
