Thread: Upgrading alternator |
Bronze Member Username: 2000celica
Roanoke,
VA
U.s.
Post Number: 12 Registered: Jan-08
| Posted on Friday, February 01, 2008 - 07:40 pm: |
i've got a 2000 celica and am thinking about upgrading the alternator on my car to a 170 amp. if i do this what else should i take into consideration. i've seen in another post to get a good battery, what types of batteries would i be looking for. |
Relevant Product Info
Gold Member Username: Nd4spd18
Northwest PA
Post Number: 5962 Registered: Jul-06
| Posted on Friday, February 01, 2008 - 07:55 pm: |
You don't really need a new battery unless your going to do comps.......... Is that the biggest alternator you can get? Get that biggest one, preferably 200+ amp is available. |
Roanoke,
VA
U.s.
Post Number: 13 Registered: Jan-08
| Posted on Saturday, February 02, 2008 - 12:09 am: |
where would i find such an alternator? |
Roanoke,
VA
U.s.
Post Number: 14 Registered: Jan-08
| Posted on Saturday, February 02, 2008 - 12:13 am: |
oh and would having a larger alternator effect how my car ran, such as pulling the engine down, or would it really not make much of a difference in that aspect? |
Bronze Member Username: Waresgaragestereo
Fort Valley,
GA
United States
Post Number: 100 Registered: Jan-08
| Posted on Saturday, February 02, 2008 - 12:14 am: |
Also when you upgrade to a bigger alternator, you need to upgrade the big 3. Google the "big three" upgrade and click the first link to get directions on how. You will ne 0ga or bigger for the big 3 upgrade. especially with the 200+ amp alt. or http://www.the12volt.com/installbay/forum_posts.asp~TID~73496~PN~1 this goes right to it. |
Silver Member Username: Waresgaragestereo
Fort Valley,
GA
United States
Post Number: 101 Registered: Jan-08
| Posted on Saturday, February 02, 2008 - 12:20 am: |
No a ho alt woun't make the engine drag, it just produces more amps so that you can run more electrical accessories in the car. it puts more power out. i.e if you have a large amp that makes the lights dim in the car when it hits, a high output alt will stop it. |
Roanoke,
VA
U.s.
Post Number: 17 Registered: Jan-08
| Posted on Saturday, February 02, 2008 - 06:35 am: |
thanx for the info. |
Roanoke,
VA
U.s.
Post Number: 22 Registered: Jan-08
| Posted on Sunday, February 03, 2008 - 08:34 pm: |
ok guys i found some info on alternator amps vs. current draw. if i'm wrong here let me know. so far i have a 1500 watt, 500 rms 4 channel amp. current draw should be 23.2. i want to get a 1000 rms mono amp. current draw on that should be 46.3. if i got a 170 amp alternator its able current would be 68. total draw would be 69.5, 1.5 over available current. would this 1.5 matter at all and are my calculations correct? |
Fort Valley,
GA
United States
Post Number: 106 Registered: Jan-08
| Posted on Sunday, February 03, 2008 - 09:57 pm: |
a 170 amp alt should do it. don't understand them #'s and stuff. |
Northwest PA
Post Number: 5987 Registered: Jul-06
| Posted on Monday, February 04, 2008 - 02:09 pm: |
Those calculations are useless since current draw will by dynamic not constant. Get a 200+ amp alternator if you can |
