Home > Message Board > Car Audio > Amplifiers > Archive through February 29, 2008 > Memphis Belle Amp
Author Thread: Memphis Belle Amp
Username: Ltweeks33
Memphis, Tn
Usa
Hello all, I have read many posts as guest, and now have my own question. I am novice in car audio so I have gone with a local car installers advice. Here is what I was "influenced" to buy. My system is built around a pioneer avic-n4 nav radio. I wanted an amp and subs, so I was sold two kicker cvr10's in an enclosure under rear seat of Dodge Ram. They are powered by a Memphis Car Audio 16-mch1300 amp, probably overkill for amp but at time it was only one that fit dimensions behind enclosure. Are there any issues that I have with this setup? Does the fact that the speaker's surround edge is against the bottom of the seat affect the speaker -- My daughters love the vibration it gives them when they sit above the speakers!!!
Username: Nd4spd18
Northwest PA
Post Number: 5913
Is that amp powering anything besides the subs? If not, you can almost certainly get a good amp for less....... they are probably going to way overcharge you for that thing.
Username: Ltweeks33
Memphis, Tn
Usa
Failed to ask. I have 4 gauge coming from stock battery. Would a capacitor be recommended for this setup? Using stock battery and alternator now.
Username: Ltweeks33
Memphis, Tn
Usa
The amp is powering the stock front and rear speakers as well. And what would you recommend for their replacement as tha? is my next project.
Username: Niiro
Hyattsville, Maryland
United states
That memphis amp sounds like a mono-amp you may want to consider a 4ch amp of your choice buddy if this is what Iam getting from you questioning.
Home > Message Board > Car Audio > Amplifiers > Archive through February 29, 2008 > Memphis Belle Amp [ « Previous ] [ Next » ]
