Home > Message Board > Car Audio > Speakers > Archive through February 16, 2008 > Speakers Cut out but still play
Author Thread: Speakers Cut out but still play
Username: Kober
Post Number: 47
My speakers all the sudden dont play but the sub does. Turned car off once turned it back on, and then speakers came came back on for about 4 seconds.. Tried it several more times.. cleaned cd everything.. Do I gotta pull the deck to see if any wires are touching in the back? Or is my deck going out?
Username: Waresgaragestereo
Fort Valley, GA
United States
Post Number: 83
it could be either of those, from what you're describing, it sounds like to me the cd deck is going. But check the wires just in cade, i'm pretty sure it's the deck tho.
Home > Message Board > Car Audio > Speakers > Archive through February 16, 2008 > Speakers Cut out but still play [ « Previous ] [ Next » ]
