Thread: What are these used for? |
Silver Member Username: Stateprop486
PA
Post Number: 105 Registered: Jan-08
| Posted on Friday, January 25, 2008 - 07:19 pm: |
are line drivers used to increase pre-out volts on a headunit? lol i dunno thats why im asking. http://cgi.ebay.com/NEW-Phoenix-Gold-LINE-DRIVER-2-In-2-Out-2CH-Line-TLD22_W0QQi temZ120213795198QQihZ002QQcategoryZ14931QQssPageNameZWDVWQQrdZ1QQcmdZViewItem |
Gold Member Username: Van_man
Boston South,
MA
Post Number: 3284 Registered: Mar-06
| Posted on Friday, January 25, 2008 - 07:23 pm: |
yes |
PA
Post Number: 106 Registered: Jan-08
http://cgi.ebay.com/Pac-Turbo-1-Turbo1-Pre-Amp-Line-Driver-Signal-Amplifier_W0QQ itemZ190192413755QQihZ009QQcategoryZ60208QQssPageNameZWDVWQQrdZ1QQcmdZViewItem ? |
Boston South,
MA
Post Number: 3286 Registered: Mar-06
| Posted on Friday, January 25, 2008 - 07:31 pm: |
same thing, just an off brand. |
PA
Post Number: 107 Registered: Jan-08
| Posted on Friday, January 25, 2008 - 07:37 pm: |
so i just bought a 7" indash panasonic indash it only has 2volts pre-out could i use one of these to increase it to like 5 volts without damaging anything? |
Platinum Member Username: Bestmankind
RD 1000.1D with SI MAG...
Post Number: 17370 Registered: Oct-05
| Posted on Friday, January 25, 2008 - 07:41 pm: |
if you must use a line driver, look at the memphis one. i really like that one. its very simple and works great. but before you go out and do that, first see how it sounds. you never know man. you might like it. |
Post Number: 17371 Registered: Oct-05
http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=4349 |
Gold Member Username: Denali_on_22s
The kids like my rhyme...
Post Number: 3740 Registered: Feb-06
| Posted on Friday, January 25, 2008 - 07:42 pm: |
i wouldn't worry about it man, youll be fine with 2v... line drivers provide shitty signals a lot of the time |
PA
Post Number: 108 Registered: Jan-08
| Posted on Friday, January 25, 2008 - 07:43 pm: |
haha yea thanks chad i saw the memphis one on Ebay, but these do really work though? the line drivers? o yeah i get it on Tuesday i cant wait. lol |
Post Number: 17373 Registered: Oct-05
| Posted on Friday, January 25, 2008 - 07:44 pm: |
well i've seen the memphis one in action and it does work well. |
PA
Post Number: 109 Registered: Jan-08
| Posted on Friday, January 25, 2008 - 07:45 pm: |
lol im just afraid the i wont be use to the sound because the premier HU i have now is 5v pre-out. so i dunno lol...o well if i dnt like it ill just sell it on ebay. |
Post Number: 17374 Registered: Oct-05
| Posted on Friday, January 25, 2008 - 07:49 pm: |
after you get the indash and you don't like the sound, get yourself a audiocontrol eq. audiocontrol ups the voltage too. it has a built in line driver. |
PA
Post Number: 110 Registered: Jan-08
| Posted on Friday, January 25, 2008 - 07:51 pm: |
o really, which one would u suggest chad? thanks for your input guys, i really appreciate it. o yea reece any luck on findin indash monitors compatible with the pioneer dvd playeR? |
Post Number: 17375 Registered: Oct-05
| Posted on Friday, January 25, 2008 - 07:57 pm: |
don't know. there are many to choose from. you gotta check to see which would be most suitable for you. anyways don't concern yourself about that right. first install the indash. you might like it. lol. |
PA
Post Number: 111 Registered: Jan-08
| Posted on Friday, January 25, 2008 - 08:07 pm: |
haha okay bro. thanks again. |
Silver Member Username: Mmaudioconcepts
Post Number: 369 Registered: Jan-07
| Posted on Friday, January 25, 2008 - 08:44 pm: |
the JL audio line driver is great as well... |
