Home > Message Board > Car Audio > Subwoofers > Archive through January 26, 2008 > What type box should i use?
Author Thread: What type box should i use?
Username: Blaaaahhhhh
Warrior, Alabama
Usa
Post Number: 12
alright i have 2 pioneer premiers bridged to a 1200 watt sony amp, im a newb and only know the basics so dont make fun, what kind of box do i use i have the amp turned all the way up to the max too. should i use a sealed box or vented?
Username: Mgbcs
Lincoln, Nebraska
Post Number: 2063
What do you mean amp tuned all the way up? That sounds bad...
To answer your initial question, you may as well port those.
Username: Big_edge_head
Milwaukee, Wisconsin
IF IT DOESNT...
Post Number: 1241
The gain all the way up! turn it down. Its not a volume control. Its a control to match the preout voltage of your Head Unit.
http://www.bcae1.com/gaincon2.htm
Warrior, Alabama
Usa
Post Number: 13
like i said you guys im am a newb i need help so how should i go about settin my amp up with my head unit for starters?
Username: Durski
Post Number: 229
comedy
lol
for newb style go with a sealed box, just cuz its easier to make and you don't seem like you know exactly what you want outta the system, so if you want ports you can always cut them in later.
that is, if you plan to build it.
there are other issues here that catch my eye, but being somewhat of a newb myself I don't feel I would be the right person to skool ya.
hope you have receipts, lol, good luck.
Username: Mgbcs
Lincoln, Nebraska
Post Number: 2065
Read the link he gave you.
Username: Mgbcs
Lincoln, Nebraska
Post Number: 2066
"if you want ports you can always cut them in later"
How do you propose that?
IF IT DOESNT...
Post Number: 1243
aero ports maybe.....
Username: Mgbcs
Lincoln, Nebraska
Post Number: 2067
That's all I could think of. But even then, there would be a little extra planning involved.
Warrior, Alabama
Usa
Post Number: 14
well that doesnt matter guys cause i already have a sealed box and a ported one but idk which one to use
Username: Mgbcs
Lincoln, Nebraska
Post Number: 2070
Well in my first post I answered that question.
However, we need to know how big the enclosures are and what the ported one is tuned to if you already have them.
Username: Durski
Post Number: 230
I was assuming that he wouldn't care about tuning, that's a quality issue and he doesn't seem to be overly concerned with quality. Cut some round holes and drop in some plastic...
personally, since u have both boxes already I would just try em both and keep whatever sounds better.
Username: Mgbcs
Lincoln, Nebraska
Post Number: 2071
"Cut some round holes and drop in some plastic..."
No don't do that.
Warrior, Alabama
Usa
Post Number: 15
well I guess ill juss test them both out but I don't know how to set my gain up still even after I looked at that link}
Username: Rovin
4 10 Pioneer...
Post Number: 12902
pioneers arent really made to go in sealed boxes
since u r a newb build a 2cuft box & port it with 1 4" pipe 12" long - this is for each sub...
Warrior, Alabama
Usa
Post Number: 16
alrite I already have a box pretty much like that so thanx
Home > Message Board > Car Audio > Subwoofers > Archive through January 26, 2008 > What type box should i use? [ « Previous ] [ Next » ]
