Thread: Need some speakers |
Silver Member Username: Kenny_hammond
Post Number: 277 Registered: Jan-05
| Posted on Friday, January 25, 2008 - 04:35 pm: |
ok mi have a 2001 dodge dually (extra cab) and i am wanting ti replace all the speakers..... i have a sony cd player just put it in today... so ....any suggestions are great... i have tweeters in the pillar (all factory) |
Gold Member Username: Bnd_rulez
Phoenix,
AZ
Post Number: 1274 Registered: Mar-05
| Posted on Friday, January 25, 2008 - 04:38 pm: |
To start off, what is you budget? Do you have an amp? Sub? What kind of sound do you want? |
Post Number: 278 Registered: Jan-05
| Posted on Friday, January 25, 2008 - 07:20 pm: |
ok i am not looking to break the bank but i am not cheap lol i am looking at some infnity kappa perfect's i would like to stay around 500 for both the fron need to be the componets and the rear can just be speakers.... i dont have anything but a headunit nothen else i am going from there ....thanks for the help guys |
Silver Member Username: Drant19
DUB-C,
TX
Post Number: 299 Registered: Aug-07
| Posted on Friday, January 25, 2008 - 09:00 pm: |
if you want to not be "cheap" you need to put an amp into the budget. running aftermarker speakers just of the HU probably wont give you the performance you want. the infinitys had a bright sound. meaning they dont have much midbass output. however, the better the install, the better sound you will get. sound deadening your doors will give you better all around reponse to any set of speakers. $500 is a good start out amount, but i wouldnt waste it on a set of infinity's when you can get much better for the same amount or even less. again like Cheese said, what kind of sound do you want? |
Post Number: 281 Registered: Jan-05
| Posted on Saturday, January 26, 2008 - 02:23 pm: |
ok well i will put in a amp or whatever it takes... i like bass and highs i listen to rock and rap and a lil country i hate anything to distort but i dont want to hear nothen but highs .....so i am lost...lol.... well i have also looked at rockford and jl so if u could just give me a opinion than that will be great i will spen like around 4 or 5 hundered on a good amp also,..... i have decided not to put any subs becaus ei realy dont need them just some good mid bass and highs..... well thanks |
Phoenix,
AZ
Post Number: 1276 Registered: Mar-05
| Posted on Saturday, January 26, 2008 - 03:12 pm: |
Well if thats your plan you could check out some Diamond Audio components or CDT. CDT have great midbass and a smooth tweeter. Slap 150to 175w to each speaker and you will be rocking and rolling. I would suggest the CDT HD line. Great speakers, won't break the bank and they can handle at least 150w. For more info on CDT's and pricing, contact ExigeAudio, or Alteraudio on this forum. They are both dealers and will be able to answer most any questions you have as well as give you a better price then a store. Diamond HEX's are great speakers too, and have good power handling too. Try to find a shop and give them a listen, the more speakers you listen to the better idea you will have of what you want ultimately get. Also, since you don't plan on getting a sub I would suggest just getting a midbass for the rear doors and setting it on the LPF (low pass filter) and running them directly off the head unit. Too much noise from the rear will distract from the front stage imaging you are trying to achieve. I decent budget amp that'll do 175x2 at 4 ohms would be a Kicker 350.4. You can find them on eBay for about $140 shipped all day long. Hope this helps, David. |
Post Number: 282 Registered: Jan-05
| Posted on Saturday, February 02, 2008 - 12:35 pm: |
hey thanks for the help ...... |
New member Username: Ewok
Fairbanks,
Alaska
U.S.A.
Post Number: 7 Registered: Jan-08
| Posted on Sunday, February 03, 2008 - 02:15 am: |
hey guys, what do you guys think of the focal 6.5 component 165 a1 access. i just got it today and hopingly to install it tommorrow, i like the wooven fiber woofer and it has a center phase plug, hope it will sound good. |
