Thread: POLO or anyone with knowledge of 16v systems |
Gold Member Username: Drivingreckless
DD 9515f,
148.2 db Mov...
Post Number: 5186 Registered: Apr-06
| Posted on Friday, January 25, 2008 - 11:15 am: |
You had a 16v system. i was wondering how you were able to charge it. did you have a voltage regulator for your alternator? also did you use a step down resistor??? in other words what is necessary to run a 16v system. |
DD 9515f,
148.2 db Mov...
Post Number: 5188 Registered: Apr-06
| Posted on Friday, January 25, 2008 - 01:09 pm: |
bump for some help. |
Gold Member Username: Big_edge_head
Milwaukee,
Wisconsin
MY SUB...
Post Number: 1233 Registered: Mar-07
| Posted on Friday, January 25, 2008 - 01:10 pm: |
u bump for some help |
Platinum Member Username: Bestmankind
RD 1000.1D with SI MAG...
Post Number: 17353 Registered: Oct-05
| Posted on Friday, January 25, 2008 - 01:14 pm: |
first you could get a 16v batt with a 12v out as well, run this to your fuse box. most starters will take 16v. next you need a big alt(200A, there really is no reason for a 300A running at 16v, you may have a harder time with the external regulator under an everyday condition). then set up your regulator to like 17.4-17.6v. 2 8v or some 16v batts in the back. |
Post Number: 17354 Registered: Oct-05
| Posted on Friday, January 25, 2008 - 01:17 pm: |
also look in to this. kinetik 16v has 12v hook up for your car and 16v for your audio system. http://www.kinetikaudio.com/hc16v.asp |
DD 9515f,
148.2 db Mov...
Post Number: 5189 Registered: Apr-06
| Posted on Friday, January 25, 2008 - 01:43 pm: |
lol you got that post from termpro.com chad.... i was thinking of doing that with the kinetik but you still need to charge the 16v system with something. |
Post Number: 17356 Registered: Oct-05
| Posted on Friday, January 25, 2008 - 01:47 pm: |
lol yeah. that is how you learn man. |
DD 9515f,
148.2 db Mov...
Post Number: 5190 Registered: Apr-06
| Posted on Friday, January 25, 2008 - 01:49 pm: |
i know...thats where i go to find all my answers but i thought id ask polo since he had a 16v system. |
Post Number: 17359 Registered: Oct-05
| Posted on Friday, January 25, 2008 - 01:50 pm: |
are you wanting to do this daily? |
DD 9515f,
148.2 db Mov...
Post Number: 5191 Registered: Apr-06
| Posted on Friday, January 25, 2008 - 01:52 pm: |
yup. and of course im going to compete. |
Gold Member Username: Extrmndor3
Http://illuzonemu.serv...,
^^^Sick Game
Post Number: 7593 Registered: Feb-06
| Posted on Friday, January 25, 2008 - 02:46 pm: |
you need a external voltage regulator.. to make your alternator push the the voltage at 16v... then u need 16 volt batteries for the back... but your main batterie has to be a 12 volt batterie and you have to buy a step down 14 volt regulator box from powermaster i beilve... so the 16volt signal it will change it back to 13-14 volts and feed your electrical system this is just for starting and the back.. but run a line from your alternator directly to the 16 volt battery bank... and ull be set.. |
DD 9515f,
148.2 db Mov...
Post Number: 5193 Registered: Apr-06
| Posted on Friday, January 25, 2008 - 02:53 pm: |
alright thats pretty much what i was thinkin about doing... i was on turbostart.com checking out all there stuff... are those good 16V battS? |
^^^Sick Game
Post Number: 7594 Registered: Feb-06
| Posted on Friday, January 25, 2008 - 03:25 pm: |
listen dumbazz... go to ebay.. get a external voltage regulator from iraggi 100 bucks... get a step down 3 volt step down from powermaster...for your electrical.. use a 12 volt batterie with the step down from powermaster use a 16 volt battery back and wire it directly to the alternator... thats it.. ull have a 12 volt supply while having a 16 volt system in the back |
Gold Member Username: Safe_cracker
Chicago,
IL
US
Post Number: 3982 Registered: Jan-06
| Posted on Friday, January 25, 2008 - 06:56 pm: |
I use two dual voltage 12/16V racing batteries from Jegs and a single BatCap 8400 16V. The BatCap has its own charger so whent they are all hooked up together the one charger takes care of all the batteries at once. I have an Iraggi alt and external regulator but only use it if I do not have access to my charger when needed, I have no dimming at all because it runs fully off the bank. Polo.. |
DD 9515f,
148.2 db Mov...
Post Number: 5202 Registered: Apr-06
| Posted on Saturday, January 26, 2008 - 12:34 am: |
ight cool man thanks for the input. |
^^^Sick Game
Post Number: 7599 Registered: Feb-06
| Posted on Saturday, January 26, 2008 - 12:55 am: |
ur not even gonna say to me at least a thanks azzhole? |
Chicago,
IL
US
Post Number: 3991 Registered: Jan-06
| Posted on Saturday, January 26, 2008 - 08:57 pm: |
thanks azzhole^^^^ >Polo |
